[Qgis-user] ogr2ogr doesn't connect to MS SQL Server
chris hermansen clhermansen at gmail.com
Thu Oct 20 08:03:00 PDT 2022
Michael and list,
I don't use Microsoft SQL Server, so not speaking from experience here but
this doesn't help?
https://gdal.org/drivers/vector/mssqlspatial.html
On Thu, Oct 20, 2022 at 1:40 AM Reetz, Michael (NLPV) via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hello all,
> it seems that nobody has an idea. I’ve found some tips (some of them
> really old) to install the latest ODBC-Driver from Microsoft or the SQL
> Server Native Client. First is installed, second is not supported in SQL
> Server 2019. Another tip was to rename or delete ogr_MSSPATIAL.dll but this
> dll isn’t installed on my system (obviously not part of the QGIS
> installation package).
> So, it looks as if ogr2ogr is not really helpful for me and I have to look
> for another tool.
> Best regard
> Michael
> *Von:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *Im Auftrag von *Reetz,
> *Gesendet:* Mittwoch, 19. Oktober 2022 12:50
> *An:* qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] ogr2ogr doesn't connect to MS SQL Server
> ACHTUNG!! Diese E-Mail erreicht Sie von einem Absender außerhalb der
> niedersächsischen Landesverwaltungs-Infrastruktur mit TLS-Verschlüsselung.
> Bitte klicken Sie auf keine Links oder öffnen Sie keine E-Mail-Anhänge,
> falls Sie den Absender nicht kennen und nicht wissen, ob der Inhalt sicher
> ist.
> Dear QGIS users,
> we are using MS SQL Server 2019 as basis for Geoserver and GIS software.
> There are a lot of tables that have attributes of the types geometry and/or
> geography. I can load these tables into QGIS (3.22.8) projects without any
> problems.
> Now I’m asked to add an geography attribute to one table that has already
> an geometry attribute and populate it with coordinates by transforming the
> geometry values. I’ve found code how to do this with ogr2ogr but when I run
> it I receive the error message “Unable to open datasource ‘MSSQL:server=<my
> server IP>;database=<my database>;trusted_connection=yes;' with the
> following drivers”. MSSQLSpatial is not listed but should be part of the
> ODBC driver. Any idea? Which driver QGIS is using?
> Best regards
> Michael
> Michael Reetz
> Datenbanken und Anwendungsentwicklung
> Nationalpark-Verwaltung Niedersächsisches Wattenmeer
> Virchowstr. 1 | 26382 Wilhelmshaven
> Tel.: +49 (0) 4421 911 291
> e-mail: michael.reetz at nlpvw.niedersachsen.de
> <michael.reetz at nlpv-wattenmeer.niedersachsen.de>
> Web: https://www.*nationalpark-wattenmeer.de
> <http://nationalpark-wattenmeer.de>*
> Qgis-user mailing list
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221020/45176c6d/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221020/45176c6d/attachment.png>
