[Qgis-user] Georeferencer issue
Lester Anderson arctica1963 at gmail.com
Fri Oct 21 22:44:39 PDT 2022
I did have SCP installed and that was the issue! Thanks for the pointers. I
uninstalled that plugin and now the default profile works fine for
georeferencing.
Lester
On Fri, 21 Oct 2022 at 17:07, Andrea Giudiceandrea via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Il 21/10/2022 17:00, Lester Anderson ha scritto:
> > I created a new user profile and the georeferencer worked fine. Not
> > sure what was wrong with the default profile!
> > I guess there must be some configuration issue in the default profile.
> Hi Lester,
> e.g. some old versions (<7.10.8) of the The Semi-Automatic
> Classification Plugin (SCP) are known to be causing troubles to the
> Georeferencer core plugin.
> See
> https://github.com/semiautomaticgit/SemiAutomaticClassificationPlugin/issues/189
> Best regards.
> Andrea
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221022/ec26a445/attachment.htm>
