[Qgis-user] Faster Intersects
Raymond Nijssen
r.nijssen at terglobo.nl
Fri Sep 9 10:49:16 PDT 2022
Great! \o/
On 09-09-2022 19:25, Dennis Burgess wrote:
> That did it!!! I was unware that GeoPackage’s are SUPER fast and that I
> could SAVE a CSV as a GeoPackage file. . There is no metho to create
> indexes though once I do this, but now it runs in about 2 min! lol
> *LTI-Full_175px*
> *Dennis Burgess*
> *Author of "Learn RouterOS- Second Edition”
> *Link Technologies, Inc*-- Mikrotik & WISP Support Services
> *Office*: 314-735-0270 Website: http://www.linktechs.net
> <http://www.linktechs.net/>
> Create Wireless Coverage’s with www.towercoverage.com
> <www.towercoverage.com>
> Need MikroTik Cloud Management: https://cloud.linktechs.net
> <https://cloud.linktechs.net>
> *From:* Alexandre Neto <senhor.neto at gmail.com>
> *Sent:* Friday, September 9, 2022 12:20 PM
> *To:* Dennis Burgess <dmburgess at linktechs.net>
> *Cc:* Raymond Nijssen <r.nijssen at terglobo.nl>; QGIS User
> <qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] Faster Intersects
> Following raymond advice,
> Move the CSV to a shapefile or geopackage and run the create spatial
> index on it.
> If you have very complex polygons, use suvdivide to create smaller ones
> save it in shapefile or geopackage and run create spatial index on it.
> https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#subdivide
> <https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#subdivide>
> I would try with a smaller subset of points to test the improvement
> speed before trying to run on the full dataset again.
> Answering your question, yes I am pretty sure postgis is much faster
> than mssql, and yes I think most recent versions of PostgreSQL PostGIS
> make use of more than one core.
> Good luck
> A sexta, 9/09/2022, 17:59, Dennis Burgess via Qgis-user
> <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> escreveu:
> In the format, are you talking about the shape or the CSV with
> 2million lines?
> Dennis Burgess
> Link Technologies, Inc -- Mikrotik & WISP Support Services
> Office: 314-735-0270 Website: http://www.linktechs.net
> <http://www.linktechs.net>
> <http://www.towercoverage.com>
> -----Original Message-----
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of Raymond
> Nijssen via Qgis-user
> Sent: Friday, September 9, 2022 11:11 AM
> To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Faster Intersects
> Some things to check:
> * Is your data local?
> * Is it in a fast file format? (for example .gpkg or .shp and not
> .csv or .geojson)
> * Does the data have a spatial index?
> * Is the geometry very complicated, like a huge multi polygon with
> thousands of vertices and islands? In that case, split it up in
> several polygons.
> Hope this helps. Anyway, it should not need to take this long.
> Raymond
> On 09-09-2022 16:28, Dennis Burgess via Qgis-user wrote:
> > How can I speed up Intersects? Right now I have a single geometry
> > file, but then have about 2 million points that I need to understand
> > what intersects that geometry. Right now its taking 3 days?
> > QGIS-bin.exe is only using 11% CPU.. ☹
> > Dennis
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
