[Qgis-user] Problems with gdal
boxerg at iinet.net.au boxerg at iinet.net.au
Sat Sep 10 16:06:33 PDT 2022
I have deleted all my qgis installation files and re-loaded the program.
This seems to have worked, but I now have to reload all my plugins and other
settings. Seems my gdal file was somehow corrupted.
Cheers Grant
-----Original Message-----
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of
qgis-user-request at lists.osgeo.org
Sent: Sunday, 11 September 2022 3:00 AM
To: qgis-user at lists.osgeo.org
Subject: Qgis-user Digest, Vol 199, Issue 10
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	https://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Qgis-user digest..."
Today's Topics:
   1. GDAL problem (boxerg at iinet.net.au)
   2. Re: GDAL problem (Andrea Giudiceandrea)
   3. Re: QGIS freezes at loading screen (Richard Duivenvoorde)
   4. (no subject) (Marco G?mez)
   5. (no subject) (Marco G?mez)
Message: 1
Date: Sat, 10 Sep 2022 11:26:53 +0800
To: <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] GDAL problem
Message-ID: <13ab01d8c4c5$2c10ce90$84326bb0$@iinet.net.au>
Content-Type: text/plain; charset="us-ascii"
Hi all, when I try to pansharpen an image using gdal, I get the following
message. Any thoughts?
QGIS version: 3.26.2-Buenos Aires
QGIS code revision: feec3d3b
Qt version: 5.15.3
Python version: 3.9.5
GDAL version: 3.5.1
GEOS version: 3.10.3-CAPI-1.16.1
PROJ version: Rel. 9.1.0, September 1st, 2022
PDAL version: 2.4.3 (git-version: 6311a6)
Algorithm started at: 2022-09-10T11:24:16
Algorithm 'Pansharpening' starting.
Input parameters:
{ 'EXTRA' : '', 'OPTIONS' : '', 'OUTPUT' :
'D:/Projects/REE/PRS_L2D_STD_20210502012240_20210502012244_0001/SWIR_Panshar
pened.vrt', 'PANCHROMATIC' :
'D:/Projects/REE/PRS_L2D_STD_20210502012240_20210502012244_0001/NolansBore_S
pectraCube_SWIR.tif', 'RESAMPLING' : 2, 'SPECTRAL' :
pectraCube_SWIR.tif' }
GDAL command:
gdal_pansharpen.bat
D:\Projects\REE\PRS_L2D_STD_20210502012240_20210502012244_0001\NolansBore_Sp
ectraCube_SWIR.tif
ectraCube_SWIR.tif
D:/Projects/REE/PRS_L2D_STD_20210502012240_20210502012244_0001/SWIR_Pansharp
ened.vrt -r cubic -of VRT
GDAL command output:
Process gdal_pansharpen.bat failed to start. Either gdal_pansharpen.bat is
missing, or you may have insufficient permissions to run the program.
Execution failed after 0.17 seconds
Loading resulting layers
Algorithm 'Pansharpening' finished
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20220910/19d9aa87/at
tachment-0001.htm>
Message: 2
Date: Sat, 10 Sep 2022 08:24:21 +0200
From: Andrea Giudiceandrea <andreaerdna at libero.it>
Subject: Re: [Qgis-user] GDAL problem
Message-ID: <a415b361-d76c-b21f-cc41-000c0dd5c5bb at libero.it>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
> *boxerg at iinet.net.au*boxerg at iinet.net.au
> <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20
> GDAL%20problem&In-Reply-To=%3C13ab01d8c4c5%242c10ce90%2484326bb0%24%40
> iinet.net.au%3E>
> /Fri Sep 9 20:26:53 PDT 2022/
> -- Hi all, when I try to pansharpen an image using gdal, I get the
> following message.
> gdal_pansharpen.bat is missing, or you may have insufficient permissions
to run the program.
Hi boxerg,
what is your operative system exactly? Is the gdal_pansharpen.bat file
available in your QGIS_install_dir\apps\Python39\Scripts\ folder? Have you
tried to run the command in the OSGeo4W Shell? What errors are displayed, if
any?
Best regards.
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20220910/01faebe1/at
tachment-0001.htm>
Message: 3
Date: Sat, 10 Sep 2022 09:47:00 +0200
From: Richard Duivenvoorde <rdmailings at duif.net>
To: Torben Kreuzberg <TorbenKreuzberg at web.de>,
Subject: Re: [Qgis-user] QGIS freezes at loading screen
Message-ID: <6501ebd5-358c-9df4-92e7-61b2e2cf4695 at duif.net>
Content-Type: text/plain; charset=UTF-8; format=flowed
On 9/9/22 17:06, Torben Kreuzberg via Qgis-user wrote:
> Hello everyone,
> i have the following problem:
> when i try to start QGIS it freezes at the loading screen at last step
("QGIS is ready"/"QGIS ist startklar").
> It happens at the start of every project i try to open.
And it is at the end finally loading (if so, could it be a proxy setting?
Qgis maybe trying to fetch stuff from internet, OR trying to open network
connections (QGIS browser panel?)?
If all fails, either create a new profile in QGIS or just move you 'default'
profile folder and let QGIS create a new one?
You can always try to move back or copy over plugins/scripts/whatever you
need from your old profile
HTH
Regards,
Message: 4
Date: Sat, 10 Sep 2022 07:40:14 -0500
To: Qgis-user at lists.osgeo.org
Subject: [Qgis-user] (no subject)
Message-ID:
	<CAFSyRHyUvjoPGnVePuf1BUy5cuCFGU6hg7uytJesCoC2Ja5L5A at mail.gmail.com>
Anular
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20220910/d116d8a0/at
tachment-0001.htm>
Message: 5
Date: Sat, 10 Sep 2022 07:40:32 -0500
Message-ID:
	<CAFSyRHz1W7mug0veTYcsScmhATNqGy0G5sMWWmg+3WFZ243qVQ at mail.gmail.com>
Anular
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20220910/84f9d2d6/at
tachment-0001.htm>
Subject: Digest Footer
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
End of Qgis-user Digest, Vol 199, Issue 10
