[Qgis-user] Spatial indexes in virtual layers
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Tue Sep 13 02:31:15 PDT 2022
Hi list,
using spatial predicates on virtual layers is slow by default as spatial
indexes are not used.
https://docs.qgis.org/testing/en/docs/user_manual/managing_data_source/create_layers.html#use-of-indexes
says that one can use the _search_frame_ column to "trigger the use of a
spatial index". The page has an example where this is compared to a
MBR/BBOX:
SELECT * FROM vtab WHERE
_search_frame_=BuildMbr(-2.10,49.38,-1.3,49.99,4326)
What does it actually mean and what does it really do? What is the
_search_frame_ really and why can we compare it for *equality* against a
simple bounding box? Is the "=" operator used for a different logic?
Does it magically "trigger" the use of the sources' spatial indexes in
the background? That would surprise me.
The original docs of virtual layers at
https://github.com/mhugo/qgis_vlayers#index-support _search_frame_ say
 > For spatial indexes, a 'hidden' field named '/search_frame/' is
created for each virtual table (i.e. each referenced layer of the
virtual layer). The bounding box of the given geometry will be used to
restrain the query to a particular region of space. This bounding box is
passed to the underlyng provider by a QgsFeatureRequest with a "filterRect".
and show this example:
 > SELECT * FROM pt, poly WHERE pt._search_frame_ = poly.geometry AND
Intersects(pt.geometry, poly.geometry)
I have some trouble parsing that in my brain. Does it mean that there
are N QgsFeatureRequests and each uses the _search_frame_ BBOX of its
feature geometry as filterRect?
It would be great to demystify this and make people more aware of how to
make their virtual layers not slow.
Thanks!
Hannes
PS: QgsFeatureRequest.setFilterRectcould use a note about the spatial
predicate being used to determine which features to return. Intersection
probably but it is not clear. People might expect Within. Might file/fix
this later but feel welcome to do it before me. :)
Johannes Kröger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220913/34e66a49/attachment.htm>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220913/34e66a49/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220913/34e66a49/attachment.sig>
