[Qgis-user] Oriented Minimum Bounding Box
Andrea Giudiceandrea andreaerdna at libero.it
Fri Sep 16 03:29:29 PDT 2022
> *Jon*jonr at destar.net
> <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Oriented%20Minimum%20Bounding%20Box&In-Reply-To=%3Ca56b031fd57a558f91f3ae09368131a0429420be.camel%40destar.net%3E>
> /Thu Sep 15 20:40:20 PDT 2022/
> When trying to put a minimum bounding box over a shape file for a
> county, I keep getting thousands of Bounding Boxes. I am iterating over
> everything in the shaoe file but I only want one Bounding Box at the
> end of the run rather than a Bounding Box for each polygon.
Hi Jon,
what processing algorithm exactly are you using? What parameters and how
did you set for the processing algorithm? What do you mean with "I am
iterating over everything"?
Regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220916/3722cd58/attachment.htm>
