[Qgis-user] How to permanently enable a plugin?
Raymond Nijssen r.nijssen at terglobo.nl
Fri Apr 7 04:49:42 PDT 2023
Hi Adam,
Normally it should work as you wish for.
Once I had a customer with this problem. They were using Citrix and the
user home directory (where plugins are stored) was either cleared at
every startup, or the server where QGIS was running was a different
every time. Could that be the problem?
Hope this helps,
Raymond
On 07-04-2023 13:36, Adam Nielsen via QGIS-User wrote:
> Hi all,
> Every time I load QGIS, I have to go to the Plugins menu, choose
> "Manage and Install Plugins", then go to the "Installed" section and
> tick the plugins that I want to use, in order for them to become
> available in the menu and on the toolbar.
> Is there a way to permanently have them ticked, like the system plugins
> are, so that I don't have to go in and re-enable them every time I load
> QGIS?
> Thanks,
> Adam.
> QGIS version: 3.30.0-'s-Hertogenbosch
> Qt version: 5.15.8
> Python version: 3.10.10
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
