[Qgis-user] Qgis 3.32 Lima desktop missing vector tab data management use ; vectorlayers merge ( samenvoegen )
marc.devits at telenet.be
Tue Aug 8 02:34:50 PDT 2023
YES
This was the problem .
I fixed now . thanks for your help.
Marc De Vits
Van: Alexandre Neto <alexandre.neto at qcooperative.net>
Verzonden: dinsdag 8 augustus 2023 09:46
Aan: marc.devits at telenet.be; QGIS User <qgis-user at lists.osgeo.org>
Onderwerp: Re: [Qgis-user] Qgis 3.32 Lima desktop missing vector tab data management use ; vectorlayers merge ( samenvoegen )
It seems the problem is another. You have the processing plugin deactivated.
Go to the plugins menu and choose the manage and install plugins. In the list of installed plugins, make sure to activate processing. This will fix the merge vector missing in the vector menu.
Alexandre Neto
User support
www.qcooperative.net <http://www.qcooperative.net>
A terça, 8/08/2023, 06:55, <marc.devits at telenet.be <mailto:marc.devits at telenet.be> > escreveu:
Hello alex ,
I use a dutch qgis version . I can not find processing toolbox in processing menu . what do you mean ?
I assume processing = bewerken . But in bewerken there is no search tool and this is only to modify active layer
This is my Qgis .
Van: Alexandre Neto <alexandre.neto at qcooperative.net <mailto:alexandre.neto at qcooperative.net> >
Verzonden: dinsdag 8 augustus 2023 00:40
Aan: marc.devits at telenet.be <mailto:marc.devits at telenet.be>
CC: QGIS User <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> >
Hello Marc,
Enable the processing toolbox in the processing menu.
Then, in the processing toolbox use the search to find vector merge.
Best regards,
Alexandre Neto
A segunda, 7/08/2023, 23:19, marc.devits--- via QGIS-User <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> > escreveu:
In an older QGis installation on windows msi , Hannover , I used the tab “ vector “ and the possibility of datamanagement use to be able to merge vectorlayers . I manage to merge about 100 of individual layers ( shp files ) into 1 layer . This I could export as kml file and so I did install 1 map at my maps in google.
I did install this week the QGis 3.32 latest version but I miss now this possibility . and also in my older QGis hannover installation this possibility did disappear . Should I install a specific plug in for this ?
I did already uninstall the Q Gis 3.32 from my desktop computer and reinstalled today but still missing the vector merging possibility. In the first QGis 3.32 Lima installation I did install the GPS plugin and this was obvious under the vector tab .
Hope for help
Marc
QGIS-User mailing list
QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230808/4fd082f4/attachment.htm>
More information about the QGIS-User
