[Qgis-user] QGIS-User Digest, Vol 210, Issue 10
boxerg at iinet.net.au
Sat Aug 12 14:38:36 PDT 2023
Thanks Martin,
I ended up using the Georeferencer and the ground control point coordinates
with a Helmert transformation. That worked well.
Cheers Grant
-----Original Message-----
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of
qgis-user-request at lists.osgeo.org
Sent: Sunday, August 13, 2023 3:00 AM
To: qgis-user at lists.osgeo.org
Subject: QGIS-User Digest, Vol 210, Issue 10
Send QGIS-User mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of QGIS-User digest..."
Today's Topics:
1. Re: Shifting a Geotiff image (Martin Weis)
Message: 1
Date: Sat, 12 Aug 2023 18:17:51 +0200
From: Martin Weis <martin.weis.newsadress at gmx.de>
Subject: Re: [Qgis-user] Shifting a Geotiff image
Message-ID: <e8655a03-6fe6-0efd-ef1c-22ed7f9d50ff at gmx.de>
Content-Type: text/plain; charset=UTF-8; format=flowed
Dear Perth,
On 11/08/2023 09:14, Grant Boxer via QGIS-User wrote:
> I have a GeoTIFF image created using Web ODM and is mis-aligned by 1
> to 1.5 m and I would like to move the image to register with the
> surveyed ground control points. I can see vector tools to do this, but no
raster tools.
> Anyone have any suggestions.
If it just a bit off, then the plugin "Freehand raster georeferencer"
can be quick to shift it, otherwise use georeferencer from core (Layer -
georeferencer), which is especially more flexible and the right tool if you
have GCPs that you can use.
Be careful, sometimes crashes can occur with certain transformation types,
so better save beforehand (autoSaver and MemoryLayerSaver are your friends).
> Image created in WGS84 z51S.
Sound like UTM (good, metric CRS), though WGS84 might be geographic CRS
(worse, pixel size undefined/different in x,y).
Cheers
Martin
Subject: Digest Footer
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
End of QGIS-User Digest, Vol 210, Issue 10
More information about the QGIS-User
