[Qgis-user] spatial analysis toolbox - testing for autocorrelation
Francesca Parente francescaparente.rse at gmail.com
Mon Aug 14 02:57:53 PDT 2023
Thank you both! I checked that out and tried the suggested installing
procedure.. but I can't get the command prompt where to type "pip install
geopandas".
I think I'm still missing a piece, I'm not so familiar with the python
environment as you can assume.
These are the steps I followed:
[image: image.png]
[image: image.png]
Then I clicked on "python3.dll", which downloaded the file I tried to open
- but got me just another error message in QGis (saying that is an invalid
data source).
I searched online for other tips and tutorials, but (besides another
procedure using fiona) I haven't found anything more specific on this one.
Should I go into the "Scripts" folder and click on "pip.exe" or "pip3.exe"?
Thanks again for your time and any other inputs you may have!
Francesca
Il giorno ven 11 ago 2023 alle ore 19:20 Thayer Young via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> Hi Francesca,
> If you don't know how to install Geopandas, I would like to add to what
> Paolo said. Geopandas needs to be installed in the python that QGIS is
> using.
> You can check the location of the python installation by going to the
> overall preferences for QGIS (command comma on a Mac, probably control
> comma on other systems.)
> From the System tab scroll to the bottom to find the "Current environment
> variables" scroll down to find PYTHONHOME.
> This documentation page shows you more with pictures:
> https://docs.qgis.org/3.28/en/docs/user_manual/introduction/qgis_configuration.html#system-settings
> Then in Finder or Explorer, etc. you want to find  location in the file
> system. On a Mac you will need to right click on QGIS in your applications
> folder and show package contents.  Then continue through the path and
> double click to open the python3 file.
> This will bring up a python prompt where you want to type:   pip install
> geopandas   Then press enter/return. It will run for a while and hopefully
> say that you successfully installed geopandas. You will probably need to
> restart QGIS after that.
> -Thayer
> On Thursday, August 10, 2023 at 03:00:37 PM EDT,
> qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org>
> wrote:
> Date: Thu, 10 Aug 2023 17:29:39 +0300
> From: Paolo Cavallini <cavallini at faunalia.it>
> To: Francesca Parente <francescaparente.rse at gmail.com>, Francesca
>     Parente via QGIS-User <qgis-user at lists.osgeo.org>, QGIS User List
> Subject: Re: [Qgis-user] spatial analysis toolbox - testing for
>     autocorrelation
> Message-ID: <CA92BEAF-7DFA-479D-BF82-4614BF7DE30D at faunalia.it>
> Content-Type: text/plain; charset="utf-8"
> You have to install geopandas.
> Cheers.
> Il 10 agosto 2023 17:10:28 EEST, Francesca Parente via QGIS-User <
> >Hello everyone!
> >I was wondering how to perform spatial autocorrelation tests in QGis and I
> >downloaded the Spatial Analysis Toolbox
> ><https://plugins.qgis.org/plugins/spatialanalysistoolbox/> plugin.
> >I can't even open it thought and immediately got the following error
> >message:
> >*Impossibile caricare il plugin 'spatialanalysistoolbox' a causa di un
> >errore chiamando il metodo classFactory() ModuleNotFoundError: No module
> >named 'geopandas' Traceback (most recent call last):  File
> >"C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line 335, in _startPlugin
> >  plugins[packageName] = package.classFactory(iface)  File
> >"C:/Users/fparente/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\spatialanalysistoolbox\__init__.py",
> >line 36, in classFactory    from .spatialanalysistoolbox import
> >SpatialAnalysisToolboxPlugin  File
> >"C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line 799, in _import
> mod
> >= _builtin_import(name, globals, locals, fromlist, level)  File
> >"C:/Users/fparente/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\spatialanalysistoolbox\spatialanalysistoolbox.py",
> >line 38, in    from .spatialanalysistoolbox_provider import
> >SpatialAnalysisToolboxProvider  File
> mod
> >"C:/Users/fparente/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\spatialanalysistoolbox\spatialanalysistoolbox_provider.py",
> >line 35, in    from .algorithms.GWR_ import GWR_  File
> mod
> >"C:/Users/fparente/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\spatialanalysistoolbox\algorithms\GWR_.py",
> >line 23, in    import geopandas as gpd  File
> mod
> >level)ModuleNotFoundError: No module named 'geopandas'Versione Python:
> >3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914 64 bit
> >(AMD64)] Versione di QGIS: 3.18.2-Z?rich Z?rich, 515138c171 *
> >I repeated the download/install procedure, but nothing changed.
> >Does anybody know how to fix this and/or alternative ways to test for
> >spatial autocorrelation here?
> >Thanks a lot and have a good day!
> >Francesca Parente
> >_ SESS Euro PhD <https://iris.uniroma1.it/cris/rp/rp54329> in
> SocioEconomic
> >and Statistical Studies
> >_ Linked
> https://www.linkedin.com/in/francesca-parente-55194497/details/publications/
> >in
> >email: francescaparente.rse at gmail.com
> >      fparente at regione.lazio.it
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20230810/e9edad66/attachment-0001.htm
> Subject: Digest Footer
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> End of QGIS-User Digest, Vol 210, Issue 8
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230814/21c7ceaf/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230814/21c7ceaf/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230814/21c7ceaf/attachment-0003.png>
More information about the QGIS-User mailing list
