[Qgis-user] how to count overlays of objects
Ludwig Kniprath ludwig at kni-online.de
Sat Aug 19 04:59:22 PDT 2023
Hi Daniela,
possible solution:
1. run the "Union" algorithm that splits the input polygons
2. add a new integer-column to the "Union"-result-layer f. e. "num_overlays"
3. optionally an additional column with type "integer list" or "string",
if You want to see afterwards, which features intersect, f. e.
"overlay_ids"
4. run the script below, that performs a self-intersection for each
feature to find the spatial identical overlaps (Note: Layer- and
column-names hard coded, adjust if necessary)
union_layer = QgsProject.instance().mapLayersByName('Union')[0]
union_layer.startEditing()
for union_feature_1 in union_layer.getFeatures():
     num_overlays = 0
     overlay_ids = []
     for union_feature_2 in union_layer.getFeatures():
         if
union_feature_1.geometry().equals(union_feature_2.geometry()) and
union_feature_1.id() != union_feature_2.id():
             num_overlays += 1
             overlay_ids.append(union_feature_2.id())
     union_feature_1['num_overlays'] =  len(overlay_ids)
     # solution for column type "string" instead of "integer list":
     # union_feature_1['overlay_ids'] =  ','.join(str(id) for id in
overlay_ids)
     union_feature_1['overlay_ids'] =  overlay_ids
     union_layer.updateFeature(union_feature_1)
union_layer.commitChanges()
hth
Ludwig
Am 18.08.23 um 16:15 schrieb Daniela Friebel via QGIS-User:
> Dear Community
> I have a vectorlayer with many objects (polygons) that overlap. Now I
> want to create a new layer, where each overlap results in a separate
> object, which has an attribute with the number of overlaps.
> I have already tried various things, but have not yet found a
> solution. With the "union" tool I can generate the overlaps as
> objects, but I cannot count the number of overlaps.
> I am grateful for any help and hints.
> (I would like to count the overlaps to eventually create a heatmap. If
> there is a completely different way of doing this, I would also
> appreciate a tip).
> Kind regards
> Daniela
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230819/573d5ab9/attachment-0001.htm>
More information about the QGIS-User mailing list
