[Qgis-user] Error - Qgis files getting corrupted after saving
    Gómez Sánchez, Sandra
    sgomezsa at eservicios.indra.es
    Mon Aug 21 05:43:29 PDT 2023
Hello there,
I am facing an issue with the saving files from Qgis and importing them to another software.
On this case, we are changing data inside Qgis and then import that data into Keycom.
The thing is, we have 2 colleagues which are using Qgis 3.28.8 and 3.32.0 versions and after they change the data inside qgis, and they save that data, the files get corrupted;
I have been trying with my own qgis, which is 3.28.2 and in mine works perfect; I have changed their raw data and when I import that data on keycom it works, I have also sended them my own data (ready for import) to them, and they are able to import it, but once they put that data on their Qgis it gets corrupted and we can't work with it, we have checked the steps they are taking but they are doing the same as me,
We did a silly test in which I sended them my data, they imported it into keycom, it worked, then they changed one single value inside Qgis and it got corrupted; so we know that the issue is located into the "saving" form from Qgis;
We can open the files from Qgis again and they don't show signs of corruption inside, is just when we try to import them into keycom when the error is shown, so we are kinda lost here,
is there any issue / feature we have to check for?
Thank you very much,
Sandra
[Opsait]<http://www.minsait.com>
Sandra Gómez Sánchez
Este correo electrónico y, en su caso, cualquier fichero anexo al mismo, contiene información de carácter confidencial exclusivamente dirigida a su destinatario o destinatarios. Si no es vd. el destinatario indicado, queda notificado que la lectura, utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. En el caso de haber recibido este correo electrónico por error, se ruega notificar inmediatamente esta circunstancia mediante reenvío a la dirección electrónica del remitente.
Evite imprimir este mensaje si no es estrictamente necesario.
This email and any file attached to it (when applicable) contain(s) confidential information that is exclusively addressed to its recipient(s). If you are not the indicated recipient, you are informed that reading, using, disseminating and/or copying it without authorisation is forbidden in accordance with the legislation in effect. If you have received this email by mistake, please immediately notify the sender of the situation by resending it to their email address.
Avoid printing this message if it is not absolutely necessary.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230821/2f2e07a5/attachment.htm>
More information about the QGIS-User
