[Qgis-user] Error - Qgis files getting corrupted after saving
Gómez Sánchez, Sandra
sgomezsa at eservicios.indra.es
Tue Aug 22 23:20:31 PDT 2023
Hello Hugh,
Thank you very much for your answer, the problem has been solved I will post here what was causing the issue, for you to know,
When we were modifying the data inside qgis we were not exporting it but mashing the previous one by saving, and then changing the name of the file outside qgis, instead we exported the shp file from qgis and gave the file a new name from there, and the corruption of the file disappeared.
Have a nice day! 🙂
[Opsait]<http://www.minsait.com/>
Sandra Gómez Sánchez
De: Hugh Kelley <hghklly at gmail.com>
Enviado: lunes, 21 de agosto de 2023 14:55
Para: Gómez Sánchez, Sandra <sgomezsa at eservicios.indra.es>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Asunto: Re: [Qgis-user] Error - Qgis files getting corrupted after saving
Hi Sandra,
When you say "data" are you referring to spatial data saved in something like a shapefile geopackage etc, or the actual qgis file ending in .qgz or .qgs?
If it is the actual qgis file itself that you are seeing corrupted, I would not expect a qgis file created by a newer version to be backwards compatible with and older version of qgis. I often see people using older versions run into weird problems when opening a file created by a newer version. Perhaps others will say otherwise but I don't expect this to a problem that can be solved. All users should be on a common version for the best experience.
If its spatial data you're seeing corrupted that is something that should be solvable anf sharing what file type is being used might get you helpful suggestions.
As a note, because opening and saving a qgis file with a different version can cause problems across versions, like loosing symbology settings, I backup my qgis work at least once a day so that I have something recent to fall back to if an issue like this occurs.
Best,
Hugh
On Mon, Aug 21, 2023, 8:43 AM Gómez Sánchez, Sandra via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
Hello there,
I am facing an issue with the saving files from Qgis and importing them to another software.
On this case, we are changing data inside Qgis and then import that data into Keycom.
The thing is, we have 2 colleagues which are using Qgis 3.28.8 and 3.32.0 versions and after they change the data inside qgis, and they save that data, the files get corrupted;
I have been trying with my own qgis, which is 3.28.2 and in mine works perfect; I have changed their raw data and when I import that data on keycom it works, I have also sended them my own data (ready for import) to them, and they are able to import it, but once they put that data on their Qgis it gets corrupted and we can't work with it, we have checked the steps they are taking but they are doing the same as me,
We did a silly test in which I sended them my data, they imported it into keycom, it worked, then they changed one single value inside Qgis and it got corrupted; so we know that the issue is located into the "saving" form from Qgis;
We can open the files from Qgis again and they don't show signs of corruption inside, is just when we try to import them into keycom when the error is shown, so we are kinda lost here,
is there any issue / feature we have to check for?
Thank you very much,
Sandra
Este correo electrónico y, en su caso, cualquier fichero anexo al mismo, contiene información de carácter confidencial exclusivamente dirigida a su destinatario o destinatarios. Si no es vd. el destinatario indicado, queda notificado que la lectura, utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. En el caso de haber recibido este correo electrónico por error, se ruega notificar inmediatamente esta circunstancia mediante reenvío a la dirección electrónica del remitente.
Evite imprimir este mensaje si no es estrictamente necesario.
This email and any file attached to it (when applicable) contain(s) confidential information that is exclusively addressed to its recipient(s). If you are not the indicated recipient, you are informed that reading, using, disseminating and/or copying it without authorisation is forbidden in accordance with the legislation in effect. If you have received this email by mistake, please immediately notify the sender of the situation by resending it to their email address.
Avoid printing this message if it is not absolutely necessary.
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230823/0a4e0467/attachment.htm>
More information about the QGIS-User
