[Qgis-user] What is the r coordinate?
Alister Hood alister.hood at gmail.com
Mon Dec 11 17:43:50 PST 2023
Thanks, I should have found that, but was tripped up by
https://github.com/qgis/QGIS-Website/issues/961 and not reading carefully
enough.
I wondered if it was a radius, but I thought if so I would be able to type
a radius in to turn a vertex into a curve - I was mainly confused
because digitising curves doesn't work here for CompoundCurve and
MultiCurve memory layers (they are digitised as if the provider doesn't
support curves; maybe I have a plugin that is causing this problem).
Now that I've tried a CurvePolygon layer it all becomes clear.  And I see
that to convert between a vertex and a curve you select it with the node
tool and press 'o'.
Thanks.
On Tue, 12 Dec 2023 at 12:56, Emma Hain <emma at north-road.com> wrote:
> Hi Alister
> The 'r' coordinate is for the radius
> https://docs.qgis.org/3.28/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html?highlight=vertex%20editor#the-vertex-editor-panel
> Cheers
> Em
> On Tue, 12 Dec 2023 at 09:22, Alister Hood via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> The vertex editor panel always seems to include a column for an r
>> coordinate.  It always seems to be empty and anything I try to type in it
>> is thrown away.
>> What is it?  I guess I haven't been looking carefully enough, but I can't
>> seem to find it explained anywhere.
>> You can see a screenshot in the docs at:
>> https://docs.qgis.org/3.34/en/docs/training_manual/create_vector_data/create_new_vector.html?highlight=vertex%20editor#moderate-fa-using-vertex-editor-table
>> Thanks.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Emma Hain — Product Manager/Senior GIS Analyst
> emma at north-road.com / 0414 512 782
> [image: https://north-road.com]
> *North Road*
> Cartography • Development • Spatial Analysis
> *north-road.com* <http://north-road.com>
> <https://twitter.com/northroadgeo>
> <https://www.linkedin.com/company/north-road-studios>
> <https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231212/1b4e0642/attachment.htm>
More information about the QGIS-User mailing list
