[Qgis-user] QGIS for Windows with GSS/Kerberos/Active Directory
Tomas Pospisek tpo2 at sourcepole.ch
Fri Feb 3 12:08:49 PST 2023
On 03.02.23 20:06, chris hermansen wrote:
> On Fri, Feb 3, 2023 at 9:25 AM Tomas Pospisek via QGIS-User
> <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> wrote:
>     On 03.02.23 18:02, chris hermansen wrote:
>      > On Fri, Feb 3, 2023 at 8:11 AM Tomas Pospisek via QGIS-User
>     <mailto:qgis-user at lists.osgeo.org>>> wrote:
>      >     When I try to set up a connection to a Postgres/Postgis DB server with
>      >     Active Directory/Kerberos/GSS authentication the QGIS DB setup dialog
>      >     displays this message:
>      >           gssencmode value "require" invalid when GSSAPI support is not compiled in
>      >     When I check the Postgres source code [1] I see that apparently this
>      >     gets displayed when GSS support is not compiled in.
>      >     So it seems QGIS as shipped by qgis.org does not ship with GSS support?
>      >     Is that correct?
>      >     Does anybody use QGIS on Windows with GSS? How did you do it?
>      >     I could go ahead and download the EDB Postgres ZIP [3] and exctract
>      >     libpq.dll from it and replace the libqq.dll shipped by the QGIS
>      >     installer with it, but I'm not sure if that would work at all, if that
>      >     would be robust and it'll certainly be a pain to maintain.
>      >     Any pointers/suggestions/help?
>      > Maybe this is the proverbial dumb question... but why not install your
>      > EDB PostgreSQL on your windows machine and run it on a different port?
>      > And then connect to it from your QGIS instance, on that different port
>      > of course?
>     Thanks for your answer Chris, but I can't see how you your reply relates
>     to my question. I need QGIS to authenticate users with Active
>     Directory/Kerberos. That QGIS/libpq fails to do so doesn't have anything
>     to do with ports but with the fact that GSS support is not compiled into
>     the libpq that is furnished with QGIS.
> Sorry I was somehow thinking that by using a different PostgreSQL
> installation "in its entirety" you could avoid using the libqq.dll (or
> is it libpq.dll) that QGIS installs.
Yeah, that's kinda what I have in mind, however I fear DLL hell and I am
not knowledgeable how to do it "right". So that's why I am asking for
advice from people who might have travelled this path before...
> My apologies for contributing nothing useful to the solution of your
> problem.
Ah, I'm sorry for making it sound like that :-(. I'm very glad you tried
to help...! Thank you :-)!
*t
More information about the QGIS-User mailing list
