[Qgis-user] QGIS not installing properly
Alessandro Pasotti apasotti at gmail.com
Thu Feb 9 13:18:33 PST 2023
Garth,
thank you for the valuable explanation.
I am wondering if we (the QGS community) should put this information
somewhere to make it easily findable. We are currently in the process
of redesigning the QGIS website (which includes links to the downloads
for various operating systems).
Jessica,
how was your way to find a solution for your installation problem?
Where did you start your research?
Kind regards.
On Thu, Feb 9, 2023 at 10:07 PM Garth Fletcher via QGIS-User
<qgis-user at lists.osgeo.org> wrote:
> jessica swan wrote:
> > I am wanting to use QGIS for a project,
> > but it will not open on my laptop because "this device cannot scan QGIS for
> > malware". I have a MacBook Air from 2016 - its software should be updated
> > enough to run the QGIS system, but it seems that something is wrong. Could
> > I please get some assistance on the issue?
> A good problem report should include the OS X version you are using.
> I'm guessing that on a 2016 Mac you may be using OS X 10.13 (High Sierra) or possibly 10.14 or 10.15.
> By default these, and later versions such as OS X 11, refuse to run programs that are not "officially signed", UNLESS you give them permission to do so.
> You only have to give permission once (for a given app); there are 2 ways:
> 1) control-click on the application and select Open, or
> 2) right after having plain clicked and gotten the refusal, go to
>       Apple > System Preferences > Security & Privacy
>     where you may see a message about the rejection and an offer to authorize the rejected app
> I always use #1.  As I say, you only have to do it once.  Thereafter single clicking on the app, or one of its files, will start up QGIS.
> By the way, while in Security & Privacy / General you will see:
>    Allow apps downloaded from:
>      ( ) App Store
>      (o) App Store and indentified developers
> That is usually set for the 2nd choice, but might have been changed to the first
> Neither setting allows UNsigned apps, unless you give permission as outlined above for each UNsigned app you want to run.
> QGIS runs beautifully on Macs.  I'm using a 2011 Mac mini with OS X 10.13 for making maps with many hundreds of layers and many many GB of rasters, including LIDAR based DEMs with 1.5 foot resolution and orthophotography with 0.5 foot resolution.
> Cordially,
> Garth Fletcher
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
More information about the QGIS-User mailing list
