[Qgis-user] WFS - Env variable QGIS_SERVER_API_WFS3_MAX_LIMIT not working
Tommaso tommasodb at googlemail.com
Wed Feb 15 00:47:24 PST 2023
Hello,
I searched in the Qgis source code for a environment variable, which could
be used to limit WFS requests on the server side (wfs 1.0.0 and 1.1.0), but
without success.
So I assume that Qgis Server does not support it.
Can someone confirm my assumption?
Best regards, Tommaso
On Tuesday 14 February 2023 13:13:08 (+01:00), Tommaso wrote:
 > Hello Alessandro,
 > there is a way to limit old WFS requests?
 > Tommaso
 > On Tuesday 14 February 2023 12:15:22 (+01:00), Alessandro Pasotti wrote:
 > > Hi,
 > > that variable is for OAPIF (AKA WFS3) only, it does not apply to plain
old WFS.
 > > There is a bug in the manual, I'll fix that.
 > > It should read:
 > > Maximum value for limit in a OAPIF features request.
 > > On Tue, Feb 14, 2023 at 12:11 PM Tommaso via QGIS-User
 > > <qgis-user at lists.osgeo.org> wrote:
 > > > Hello,
 > > > I'm trying to limit the max number of features returned by my Qgis
Server
 > > > using the environment variable QGIS_SERVER_API_WFS3_MAX_LIMIT
 > > > QGIS_SERVER_API_WFS3_MAX_LIMIT=1000
 > > > The server seems to consider the variable and write to the log file
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_API_WFS3_MAX_LIMIT /
 > > > '/qgis/server_api_wfs3_max_limit' (Maximum value for "limit" in a
features
 > > > request, defaults to 10000): '1000' (read from ENVIRONMENT_VARIABLE)
 > > > The server should return max 1000 features, but it still returns all
 > > > features. The limit is ignored. How can I debug the problem?
 > > > My WFS request:
http://XXXXXXXXX/qgisserver?SERVICE=WFS&VERSION=1.0.0&MAP=/etc/qgisserver/project.qgs&service=WFS&request=GetFeature&typename=Gemeinde
 > > > Version: Qgis Server 3.28.0 (camptocamp docker image)
 > > > The begin of the log file:
 > > > 10:41:20 INFO Server[90]: QGIS Server Starting : 3.28.0-Firenze
 > > > (ed3ad0430f)
 > > > 10:41:20 INFO Server[90]: QGIS Server Settings:
 > > > 10:41:20 INFO Server[90]:   - QGIS_OPTIONS_PATH / '' (Override the
default
 > > > path for user configuration): '' (read from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_PARALLEL_RENDERING /
 > > > '/qgis/parallel_rendering' (Activate/Deactivate parallel rendering
for WMS
 > > > getMap request): 'false' (read from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_MAX_THREADS /
'/qgis/max_threads'
 > > > (Number of threads to use when parallel rendering is activated):
'-1' (read
 > > > from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_LEVEL / '' (Log
level): '0'
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_FILE / '' (Log file):
 > > > '/etc/qgisserver/qgisserver.log' (read from ENVIRONMENT_VARIABLE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_STDERR / ''
 > > > (Activate/Deactivate logging to stderr): '1' (read from
 > > > 10:41:20 INFO Server[90]:   - QGIS_PROJECT_FILE / '' (QGIS project
file):
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_IGNORE_BAD_LAYERS / ''
(Ignore
 > > > bad layers): 'false' (read from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_CACHE_DIRECTORY /
 > > > '/cache/directory' (Specify the cache directory):
 > > > '/tmp/profiles/default/cache' (read from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_CACHE_SIZE / '/cache/size'
 > > > (Specify the cache size): '268435456' (read from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_SHOW_GROUP_SEPARATOR /
 > > > '/locale/showGroupSeparator' (Show group (thousands) separator):
'false'
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE /
 > > > '/locale/userLocale' (Override system locale): '' (read from
DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_WMS_MAX_HEIGHT /
 > > > '/qgis/max_wms_height' (Maximum height for a WMS request. The lower
one of
 > > > this and the project configuration is used.): '-1' (read from
 > > > DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_WMS_MAX_WIDTH /
 > > > '/qgis/max_wms_width' (Maximum width for a WMS request. The most
 > > > conservative between this and the project one is used): '-1' (read
from
 > > > DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_API_RESOURCES_DIRECTORY /
 > > > '/qgis/server_api_resources_directory' (Base directory where HTML
templates
 > > > and static assets (e.g. images, js and css files) are searched for)
 > > > : '/usr/local/share/qgis/resources/server/api' (read from
DEFAULT_VALUE)
features
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_TRUST_LAYER_METADATA / ''
(Trust
 > > > layer metadata): 'false' (read from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_FORCE_READONLY_LAYERS / ''
(Force
 > > > to open layers in read-only mode): 'false' (read from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_DISABLE_GETPRINT / ''
(Don't load
 > > > layouts): 'false' (read from DEFAULT_VALUE)
QGIS_SERVER_LANDING_PAGE_PROJECTS_DIRECTORIES
 > > > / '/qgis/server_projects_directories' (Directories used by the
landing page
 > > > service to find .qgs and .qgz projects): '' (read from DEFA
 > > > ULT_VALUE)
 > > > QGIS_SERVER_LANDING_PAGE_PROJECTS_PG_CONNECTIONS /
 > > > '/qgis/server_projects_pg_connections' (PostgreSQL connection
strings used
 > > > by the landing page service to find projects): '' (read
 > > >   from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_PROFILE /
 > > > '/qgis/server_log_profile' (Add detailed profile information to the
logs,
 > > > only effective when QGIS_SERVER_LOG_LEVEL=0): 'false' (read from
 > > > DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_WMTS_SERVICE_URL /
 > > > '/qgis/server_wmts_service_url' (The default WMTS service URL): ''
(read
 > > > from DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_OPTIONS_PATH / '' (): '' (read
from
 > > > DEFAULT_VALUE)
from
 > > > DEFAULT_VALUE)
from
 > > > DEFAULT_VALUE)
from
 > > > DEFAULT_VALUE)
 > > > 10:41:20 INFO Server[90]:   - QGIS_SERVER_LANDING_PAGE_PREFIX /
 > > > '/qgis/server_landing_page_base_url_prefix' (Landing page base URL
path
 > > > prefix): '' (read from DEFAULT_VALUE)
QGIS_SERVER_PROJECT_CACHE_CHECK_INTERVAL /
 > > > '/qgis/server_project_cache_check_interval' (The default project
cache
 > > > check interval): '0' (read from DEFAULT_VALUE)
 > > > Thank you and best regards,
 > > > Tommaso
 > > > _______________________________________________
 > > > QGIS-User mailing list
 > > > QGIS-User at lists.osgeo.org
 > > > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
 > > > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
