[Qgis-user] QGIS under Arch-Linux
Ujaval Gandhi ujaval at spatialthoughts.com
Thu Feb 16 02:38:19 PST 2023
You can try installing using conda. The latest LTR and Current releases are
available on conda-forge
https://www.linkedin.com/posts/alexandre-neto-geo_qgis-activity-7030576968169336832-cwOm
[https://mailtrack.io/trace/link/06cdc2c4ecba275b945832ac4d3faedd2327d6e5?url=https%3A%2F%2Fwww.linkedin.com%2Fposts%2Falexandre-neto-geo_qgis-activity-7030576968169336832-cwOm&userId=8747767&signature=0470f2d3c2e9a56e]
Instructions at
https://gisunchained.wordpress.com/2019/05/29/using-qgis-from-conda/
[https://mailtrack.io/trace/link/da3735f150e424ab9bddb8b1b57cdf3d515721f8?url=https%3A%2F%2Fgisunchained.wordpress.com%2F2019%2F05%2F29%2Fusing-qgis-from-conda%2F&userId=8747767&signature=5a9cf790c9a9f4af]
Ujaval Gandhi
Spatial Thoughts
www.spatialthoughts.com
[https://mailtrack.io/trace/link/f15498490707ce09016a3abb50eacfdc7d1f6e3e?url=http%3A%2F%2Fwww.spatialthoughts.com&userId=8747767&signature=a803620488c5babb]
[data:image/gif;base64,R0lGODlhAQABAIAAAP///wAAACwAAAAAAQABAAACAkQBADs=3D]
On Thu, Feb 16, 2023 at 5:15 AM Nikos Alexandris via QGIS-User
<qgis-user at lists.osgeo.org> wrote:
> Hello, is anyone currently using QGIS under Arch-Linux (or else any
> Arch-based distribution)?  I have yet to find a way to make the SIP
> module to be installed/imported properly, and this to obviously make the
> Plugins available.  I have tried without success all available versions
> via AUR, namely :
> - qgis-ltr 3.22.16-1
> - qgis-git 3.99_master.r78162.24a71d05862-1
> - qgis 3.28.3-1
> Any help much appreciated. Kind regards, Nikos
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org [QGIS-User at lists.osgeo.org]
> [https://lists.osgeo.org/mailman/listinfo/qgis-user]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230216/cf9670ed/attachment.htm>
More information about the QGIS-User mailing list
