[Qgis-user] Polygons
Phil Wyatt phil at wyatt-family.com
Tue Feb 21 22:41:19 PST 2023
Hi Jessica,
Are these regions something common already in use (ie suburbs, localities, ABS zones etc)? You may find that a dataset may already be in existence that you can find on the web and then edit to your needs. If not then its probably a partially automated job as suggested by Nicolas, with a heap of cleaning up.
Cheers - Phil
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of jessica swan via QGIS-User
Sent: Wednesday, 22 February 2023 4:06 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Polygons
I hope everyone is well!
I am making a map marking regions for a project because I am not allowed to copy and paste an image. There are over a hundred regions for me to outline! Is there any way to automatically trace these regions and overlay that tracing on a map? It will just take so much time, otherwise!
Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230222/5f7c00e6/attachment.htm>
More information about the QGIS-User mailing list
