[Qgis-user] UnicodeDecodeError when running r.watershed
Tetsuro Kikuchi tekikuchi at affrc.go.jp
Sun Feb 26 18:08:27 PST 2023
Dear sirs,
I have encountered the following problem (UnicodeDecodeError) when I run
the 'r.watershed', one of the GRASS GIS tools, on QGIS. Could you tell
me how to solve this problem? The operating system, version of QGIS, and
error log are as follows:
OS: Windows 10 Pro, 64 bit
QGIS version: 3.22.16
Error log:
QGIS version: 3.22.16-Białowieża
QGIS code revision: 6f08e4d7
Qt version: 5.15.3
Pythonバージョン: 3.9.5
GDAL version: 3.6.2
GEOS version: 3.11.1-CAPI-1.17.1
PROJ version: Rel. 9.1.1, December 1st, 2022
PDAL version: 2.4.3 (git-version: f8d673)
アルゴリズムの開始時刻: 2023-02-27T09:06:36
アルゴリズム 'r.watershed' を開始しています...
入力パラメータ:
{ '-4' : False, '-a' : False, '-b' : False, '-m' : False, '-s' : False,
'GRASS_RASTER_FORMAT_META' : '', 'GRASS_RASTER_FORMAT_OPT' : '',
'GRASS_REGION_CELLSIZE_PARAMETER' : 0, 'GRASS_REGION_PARAMETER' : None,
'accumulation' : 'TEMPORARY_OUTPUT', 'basin' : 'TEMPORARY_OUTPUT',
'blocking' : None, 'convergence' : 5, 'depression' : None,
'disturbed_land' : None, 'drainage' : 'TEMPORARY_OUTPUT', 'elevation' :
'C:/Users/Kikuchi/Desktop/gis_data/madagascar/S16_17E46_47_DSM_utm38s_clip.tif',
'flow' : None, 'half_basin' : 'TEMPORARY_OUTPUT', 'length_slope' :
'TEMPORARY_OUTPUT', 'max_slope_length' : None, 'memory' : 300,
'slope_steepness' : 'TEMPORARY_OUTPUT', 'spi' : 'TEMPORARY_OUTPUT',
'stream' : 'TEMPORARY_OUTPUT', 'tci' : 'TEMPORARY_OUTPUT', 'threshold' :
10000 }
g.proj -c
wkt="C:/Users/Kikuchi/AppData/Local/Temp/processing_hvrJyK/4bf2cda4ce2248719eb1e3e932adc246/crs.prj"
r.in.gdal
input="C:\Users\Kikuchi\Desktop\gis_data\madagascar\S16_17E46_47_DSM_utm38s_clip.tif"
band=1 output="rast_63fbf40c542692" --overwrite -o
g.region n=8264851.5257102605 s=8144507.781290247 e=766109.6288817181
w=624443.3562344841 res=30.244720889674216
r.watershed elevation=rast_63fbf40c542692 threshold=10000 convergence=5
memory=300 accumulation=accumulationea0120119c6a4a15babab8619b5f1b43
drainage=drainageea0120119c6a4a15babab8619b5f1b43
basin=basinea0120119c6a4a15babab8619b5f1b43
stream=streamea0120119c6a4a15babab8619b5f1b43
half_basin=half_basinea0120119c6a4a15babab8619b5f1b43
length_slope=length_slopeea0120119c6a4a15babab8619b5f1b43
slope_steepness=slope_steepnessea0120119c6a4a15babab8619b5f1b43
tci=tciea0120119c6a4a15babab8619b5f1b43
spi=spiea0120119c6a4a15babab8619b5f1b43 --overwrite
g.region raster=accumulationea0120119c6a4a15babab8619b5f1b43
r.out.gdal -t -m input="accumulationea0120119c6a4a15babab8619b5f1b43"
output="C:\Users\Kikuchi\AppData\Local\Temp\processing_hvrJyK\e2342197a83f4befad482d82779a2866\accumulation.tif"
format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
g.region raster=drainageea0120119c6a4a15babab8619b5f1b43
r.out.gdal -t -m input="drainageea0120119c6a4a15babab8619b5f1b43"
output="C:\Users\Kikuchi\AppData\Local\Temp\processing_hvrJyK\7a8a7a9b65a24db8b04979b62f45643e\drainage.tif"
g.region raster=basinea0120119c6a4a15babab8619b5f1b43
r.out.gdal -t -m input="basinea0120119c6a4a15babab8619b5f1b43"
output="C:\Users\Kikuchi\AppData\Local\Temp\processing_hvrJyK\25cff09ed7f3490c9c3f7f08e5a444cd\basin.tif"
g.region raster=streamea0120119c6a4a15babab8619b5f1b43
r.out.gdal -t -m input="streamea0120119c6a4a15babab8619b5f1b43"
output="C:\Users\Kikuchi\AppData\Local\Temp\processing_hvrJyK\3620119ea0f64876a44c42944cce9a50\stream.tif"
g.region raster=half_basinea0120119c6a4a15babab8619b5f1b43
r.out.gdal -t -m input="half_basinea0120119c6a4a15babab8619b5f1b43"
output="C:\Users\Kikuchi\AppData\Local\Temp\processing_hvrJyK\8f3d244cab70412596bd62ff24741d0e\half_basin.tif"
g.region raster=length_slopeea0120119c6a4a15babab8619b5f1b43
r.out.gdal -t -m input="length_slopeea0120119c6a4a15babab8619b5f1b43"
output="C:\Users\Kikuchi\AppData\Local\Temp\processing_hvrJyK\50f5002de0e64573935eef3796e38677\length_slope.tif"
g.region raster=slope_steepnessea0120119c6a4a15babab8619b5f1b43
r.out.gdal -t -m input="slope_steepnessea0120119c6a4a15babab8619b5f1b43"
output="C:\Users\Kikuchi\AppData\Local\Temp\processing_hvrJyK\69db3625d3ab4b1f8a84155a1a9c3eff\slope_steepness.tif"
g.region raster=tciea0120119c6a4a15babab8619b5f1b43
r.out.gdal -t -m input="tciea0120119c6a4a15babab8619b5f1b43"
output="C:\Users\Kikuchi\AppData\Local\Temp\processing_hvrJyK\e59f8a76ea104a2c996f012eeb36f980\tci.tif"
g.region raster=spiea0120119c6a4a15babab8619b5f1b43
r.out.gdal -t -m input="spiea0120119c6a4a15babab8619b5f1b43"
output="C:\Users\Kikuchi\AppData\Local\Temp\processing_hvrJyK\b08c28bfb35f42f1aacf6eace36d48f5\spi.tif"
Starting GRASS GIS...
警告: マップセットの平行ロックはウィンドウズではサポートされていません。
File
"C:\PROGRA~1/QGIS32~1.16/apps/qgis-ltr/./python/plugins\grassprovider\Grass7Algorithm.py",
line 433, in processAlgorithm
Grass7Utils.executeGrass(self.commands, feedback, self.outputCommands)
File
"C:\PROGRA~1/QGIS32~1.16/apps/qgis-ltr/./python/plugins\grassprovider\Grass7Utils.py",
line 397, in executeGrass
for line in iter(proc.stdout.readline, ''):
UnicodeDecodeError: 'cp932' codec can't decode byte 0x84 in position 35:
illegal multibyte sequence
Execution failed after 1.25 秒(seconds)
Kind regards,
Tetsuro
More information about the QGIS-User mailing list
