[Qgis-user] QGIS 3.22 - Geometry by expression howto
Francesco Pelullo
f.pelullo at gmail.com
Sun Jan 1 10:22:20 PST 2023
Hi Nicolas,
Il giorno dom 1 gen 2023 alle ore 04:53 Nicolas Cadieux <
njacadieux.gitlab at gmail.com> ha scritto:
> Try decimal with commas. Check your local system settings. Could this be
> a wrong CRS problem? Try zoom to layer extent to see if they pop up in the
> wrong place. Share a few examples so we can check. Try exporting the
> geometries to Wkt in a new field to see what happens….
Thank you for your suggestions, particularly the "geom_to_WKT", it let me
discover problem.
IMHO this is a bug in "geometry by expression" algorithm.
By my exoeriences, this algorithm works _only_ if source layer has at
almost one feature.
If so, you can add new feature by this expression:
make_point(to_real(@Long),to_real(lat))
where @Long and @Lat are two project variables. Everything works as
expected.
Otherwise, e.g. when the source layer has no feature (empty layer), the
geometry by expression fails and return <null> geometry, even if the
preview in expression generator is correct.
In my test, i was usual to truncate the source layer before generate new
geometry.
This caused the fail of geometry by expression algorithm.
Instead, if i don't truncate source layer (and it has at almost one
geometry before running the model), then the algorithm works.
This is a bit confusing, because in the "geometry by expression"
documentation there is no reference to this condition.
Could this be a bug?
Is it possible to add new features to a empty layer with geometry by
expression?
Again, thank you to everyone and have a nice year!
Francesco
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230101/69084752/attachment.htm>
More information about the QGIS-User
