[Qgis-user] Service Ticket #353317 - GIS work on VPN - Archae-Aus
Andreas Neumann
a.neumann at carto.net
Thu Jan 12 01:36:44 PST 2023
Hi Virag,
This depends a bit on the data sources used in the project (files vs
databases vs web services).
But in general, VPN connections with a high latency are not recommended
and will result in really bad user experience. QGIS does a lot if I/O
when opening layers and working with databases. A low latency in your
network is crucial for having a good user experience.
If you run into such issues, I recommend using a remote desktop solution
(such as RDP, Citrix) and make sure that the QGIS desktop application
runs in the same local network like your database / data source - so
that the latency between QGIS desktop and your data sources is
minimized.
BTW: other GIS will have the same issue. For example ESRI ArcGIS desktop
wouldn't perform well in such a situation.
Greetings,
Andreas
On 2023-01-12 03:25, Virag Gandhi via QGIS-User wrote:
> Hi Team,
> We have a client who has been using QGIS application on VPN and finding
> slowness very running the same application on VPN, can you please
> advise how to do we contact your technical team to get further support
> on this and find out if it is recommended to run application on VPN or
> not?
> Please do not hesitate to contact me with the further queries.
> Virag Gandhi
> Senior IT Support Engineer
> MOBILE +61 452 585 311
> PHONE +61 8 9335 5779
> Suite 8 │ The Gateway Business Complex
> 173 Davy Street │ Booragoon │ WA │ 6154
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230112/6f69adb7/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230112/6f69adb7/attachment.png>
More information about the QGIS-User
