[Qgis-user] Export to ESRI File Geodatabase
Andrea Giudiceandrea andreaerdna at libero.it
Wed Jan 18 01:59:51 PST 2023
> *Randal Hale*
> /Tue Jan 17 12:56:50 PST 2023/
> I installed QGIS using the Stand Alone installer (after removing QGIS
> Network Install) and didn't have ESRI File Geodatabase as a choice on
> export Features. This is confirmed by another user using the standalone
> installer.
Hi Randal,
AFAIK neither the OSGeo4W stand-alone installer nor the network
installer currently install the GDAL plugin library needed to write a
File Geodatabase layer using the ESRI proprietary driver via the "Export
As" menu.
If you want to use such ESRI proprietary driver, you need to install the
package named gdal-filegdb using the OSGeo4W Setup installation interface.
Regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230118/3e7f62af/attachment.htm>
More information about the QGIS-User mailing list
