[Qgis-user] problem with cartographic label placement
gisfisch at t-online.de gisfisch at t-online.de
Thu Jan 19 05:14:05 PST 2023
Hello Andreas and list,
I am sure I’m not the first one to encounter the problem described below. So I would like to ask again. Maybe someone has an idea?
thanks a lot, the solution from Andreas is working.
But the result is not as desired. I was hoping to be able to define a ranking of placement alternatives. That is (in case of ‘B,R‘): place all the labels at the bottom and only if there is a conflict (overlap) with something else place a label at right.
But what I get is: most oft he labels are placed right, even without overlap problems (although I put ‘R‘ at the second place of the list). And only a few labels are placed at bottom.
However, the overlap problem is solved.
Is there something I could improve?
Thank you and best regards, Uwe
Von: Andreas Neumann <andreas at qgis.org>
Gesendet: Donnerstag, 12. Januar 2023 22:18
An: gisfisch at t-online.de
Cc: qgis-user <qgis-user at lists.osgeo.org>
Betreff: Re: [Qgis-user] problem with cartographic label placement
Hi Uwe,
I just tried it. 'B,BR' worked for me. Just don't use quotes before and after the separator.
Greetings,
Andreas
On Thu, 12 Jan 2023 at 22:02, Uwe via QGIS-User <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> > wrote:
Hello list,
for cartographic label placement, according to the help docs it should be possible to define position priorities in a ranking.
But when I open the editor and enter a comma separated list like:
‘B‘ , ‘BR‘
I get an error message. Entering just one value it works. But that doesn’t make sense because I need at least two values to let the label move when it collides with a feature.
What can be wrong with my input? I use 3.28.
Thanks a lot for help.
Uwe
QGIS-User mailing list
QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Andreas Neumann
QGIS.ORG <http://QGIS.ORG>  board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230119/22f27b47/attachment.htm>
More information about the QGIS-User mailing list
