[Qgis-user] QGIS memory management in LXCs vs VMs
Julien Cabieces julien.cabieces at oslandia.com
Tue Jan 24 02:49:14 PST 2023
It depends on the amount of memory you want to allocate to your QGIS
Server. IIRC, my client set 1GB and set the memory limit of they docker
to 2G, and they had approximatively 100Mb of memory taken with loaded
QGIS project.
You would have to set this param is the Nginx configuration
(if you use Nginx but it should be the same with Apache) fastcgi param,
not just system environment variable this way
fastcgi_param   GDAL_CACHEMAX 20;
if not, it won't work!
> Il giorno mar 24 gen 2023 alle ore 10:28 Julien Cabieces via QGIS-User <qgis-user at lists.osgeo.org> ha scritto:
>> The trick was to configure properly the environment variable
>> GDAL_CACHEMAX :
>> https://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_CACHEMAX
> Interesting. Which value do you have set?
> * Comune di Trento
>  via Belenzani, 19 - 38122 Trento | C.F e P. IVA: 00355870221
>  tel. +39 0461.884111 | www.comune.trento.it
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Julien Cabieces
Senior Developer at Oslandia
09.72.52.52.76
More information about the QGIS-User mailing list
