[Qgis-user] Problems by using field calculator with "generate_series" function.
Dieter Riedel
DieterRiedel at live.de
Thu Jan 26 00:55:58 PST 2023
Hi my Installation:
QGIS version
3.28.2-Firenze
QGIS code revision
b47e00ba601<https://github.com/qgis/QGIS/commit/b47e00ba601>
Qt version
5.15.3
Python version
3.9.5
GDAL/OGR version
3.6.1
PROJ version
9.1.1
EPSG Registry database version
v10.076 (2022-08-31)
GEOS version
3.11.1-CAPI-1.17.1
SQLite version
3.39.4
PDAL version
2.4.3
PostgreSQL client version
unknown
SpatiaLite version
5.0.1
QWT version
6.1.6
QScintilla2 version
2.13.1
OS version
Windows 10 Version 2009
Active Python plugins
autonumbering
0.2
ClipMultipleLayers
3.2.0
clipper
1.2
closest_points
1.0.1
db-style-manager
0.8
DEMto3D
3.51
dem_drainage_analyses
0.2
DigitizingTools
1.5.1
dimensioning
0.2
DotMap
0.2
easy_right_angle_draw
1.0
exportDBmapper
0.2.0
FreehandRasterGeoreferencer
0.8.3
inkscape2symbol-master
0.2
joinmultiplelines
Version 0.4.1
LAStools
1.4
layertilesmapcanvas
1.4
LoadQSS
1.4.2
mapswipetool_plugin
1.2
MemoryLayerSaver
4.0.4
MultiJoin
1.0
Multi_Ring_Buffer
1.1
naficp
1.0
numerator
0.5
pg_raster_import
3.1.0
PostGISQueries
0.2
postgisQueryBuilder
2.0.1
PotentialSlopeFailure
0.6
profiletool
4.2.2
qfieldsync
v4.2.0
Qgis2threejs
2.7.1
qgis2web
3.16.0
QGISSortAndNumber-master
1.0
qgis_resource_sharing
1.0.0
quick_layer
0.3
quick_map_services
0.19.32
sense_detection
0.1.0
splitmultipart
1.0.0
SplitPolygon-master
1.2
SpreadsheetLayers
2.1.0-alpha1
SRTM-Downloader
3.1.17
VoGisProfilTool
3.0.2
volume_calculation_tool
0.4
wbt_for_qgis
1.0.7
db_manager
0.1.20
grassprovider
2.12.99
MetaSearch
0.3.6
otbprovider
2.12.99
processing
2.12.99
sagaprovider
2.12.99
I Try to use the field Calculator with the function "generate_series" like you can see it at the picture. It is a solar Farm with modules there are polygons and the polygons must have a modul Namber from 1 to 11 in this case.
[cid:image001.png at 01D9316C.625DE550]
In The row above I introduce manually the numbers. When I try it with generate_series nothing happens. When I use row numbers ist now problem, but I need also the invert form from 11 to 1 an not only 1 to 11.
What is wrong in the presiders?
Thanks in Advance
Dieter Riedel
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230126/f0153ab9/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230126/f0153ab9/attachment-0001.png>
More information about the QGIS-User
