[Qgis-user] Mac problem
Jürgen E. Fischer jef at norbit.de
Fri Jan 27 00:34:40 PST 2023
Hi John,
On Thu, 26. Jan 2023 at 15:12:39 +0000, John Layt via QGIS-User wrote:
> Apple has some extra security checks when running apps for the very first
> time. If the app is signed with a developer certificate purchased from
> Apple, then you can just double-click to run the app and it gets approved.
> If the app is not signed, as in the case of QGIS, then you need to manually
> approve the app by first right-clicking on the app and selecting Open from
> the context menu. The Option key is not required. Note that on Macs, the
> right-click is not enabled by default, so you might need to enable that
> first in the System Preferences.
> I seem to recall the association was trying to obtain a
> developers certificate? Has there been any progress on that?
AFAIK we have such a certificate and the installer is signed, but after that
Apple decided that the app also has to be notarized - which we don't do yet.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230127/af628def/attachment.sig>
More information about the QGIS-User mailing list
