[Qgis-user] Editing expression in QGIS
kirk kirk at nortekresources.com
Mon Jul 10 08:17:52 PDT 2023
The short answer is yes.  You will need all the formula variables within the feature table.  Your syntax will change with ield names replaceing cell references.  You can copy your final expression and save as a text file for future use.  Alternatively, you can write a simple python script or use the graphical modeler to save your expressionKirk SchmidtSent from my Galaxy
-------- Original message --------From: Simon via QGIS-User <qgis-user at lists.osgeo.org> Date: 2023-07-10  11:58 a.m.  (GMT-04:00) To: qgis-user at lists.osgeo.org Subject: [Qgis-user] Editing expression in QGIS
Hi all,
Is it possible to add an Excel equation into QGIS via the field calculator in the attribute table window. The expression is fairly large, and the references will have to be changed but is it even do-able?
If not, is there a better tool or plugin I can use?
The goal is to add the equation, but also to be able to edit it in the future if the data changes.
Thanks,
Simon
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230710/89113cc6/attachment.htm>
More information about the QGIS-User mailing list
