[Qgis-user] Running QGis on a machine with Python 3.11 and PyCharm ?
Toussaint OTTAVI
t.ottavi at bc-109.com
Fri Jun 9 09:11:38 PDT 2023
I'm new to QGis. I'm trying to install latest version (3.28.7 LTR) on my
machine. It does not run. The startup window shows during a few seconds,
then, nothing.
I tried several older versions. None of them wants to start. The
exception is 3.14, which starts, and works perfectly.
On my machine, I already have a Python 3 installed (currently, 3.11.1),
on absolute path C:\Python, PYTHONPATH system variable pointing to it,
and system path, too. I also have PyCharm installed. I think this may be
the cause of my problem. I noticed the included interpreter (C:\Program
Files\QGIS 3.28.7\bin\python.exe) does not start at all, with Python error :
File "C:\Python\Lib\io.py", line 54, in <module>
ImportError: cannot import name 'text_encoding' from 'io' (unknown
location)
If I understand well, I'll have to write a customized startup script,
with correct path (not pointing to my c:\python\lib) so that QGis can
start using the included Python interpreter (and not my system-wide
one). But I didn't find how to achieve that.
Later, I think I'll have to write some QGis Python code. Then, I'll need
to run it in "developer" mode : being able to put the source code in a
git repository, edit the code in PyCharm, and run it. Any clues are welcome.
Thank you in advance. Kind regards
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230609/7390c381/attachment.htm>
More information about the QGIS-User
