[Qgis-user] Qgis atlas print composer : aggregate (bigger overlap)
celati Laurent laurent.celati at gmail.com
Mon Jun 12 05:45:56 PDT 2023
Thanks a lot for your usefull reply. It works well !
Le lun. 12 juin 2023 à 14:18, Stefan Giese (WhereGroup) <
stefan.giese at wheregroup.com> a écrit :
> Hi,
> you can use overlay functions instead, there you can sort the size of
> intersection and take the biggest one:
> *overlay_intersects(layer:='**PARCEL_LAYER**',  expression:="parcel_id",
> sort_by_intersection_size:='des')[0]*
> hope this helps
> Stefan
> Am 12.06.2023 um 14:04 schrieb celati Laurent via QGIS-User:
> Good afternoon,
> With Qgis 3.30, In the composer interface, I generate an atlas.
> My iteration layer is a polygonal layer (platforms). I added a text
> element to automatically get by spatial intersection the 'parcel_id'
> attribute present in another polygonal layer. I use the aggregate function
> for this task :
> *  aggregate( 'LAYER':="PARCEL_LAYER',aggregate:='concatenate',
> expression:="parcel_id", filter:=intersects(geometry(@parent), $geometry))*
> It works. But the result shows values of all the intersections. I would
> like it limit to the result of the biggest intersection. Would you know how
> to do it?
> Thanks a lot.
> QGIS-User mailing listQGIS-User at lists.osgeo.org
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Aufwind durch Wissen!
> Jetzt neu: Webinare und Online-Schulungen
> bei der www.foss-academy.com
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230612/ed5f65a8/attachment.htm>
More information about the QGIS-User mailing list
