[Qgis-user] Equations cells imported to QGIS
Ludwig Kniprath ludwig at kni-online.de
Fri Jun 16 09:53:39 PDT 2023
Hi Simon,
Excel tables don't need to be saved as delimited text, they can be
imported direct to QGis, f.e. with drag&drop.
Calculated contents in the spreadsheets are no problem, below my test
with a simple table:
(note: screenshot from LibreOffice, I hope there is no difference using
excel)
'Show Formula' as view-mode:
Normal view mode:
Imported to QGis: all cells with the last calculated and saved values
The imported table can than be joined to any existing vector-layer or
converted to point-layer f.e. via Processing Toolbox > Vector creation >
Create points layer from table.
Notes:
- You can even edit and save the imported table in QGis, but that will
convert all formulas to simple alpha-numeric contents.
- Formulas are not refreshed automatically when imported to QGis, so the
above field with the formula '=NOW()' (current time) will always show
the last calculated value in QGis, not the actual time.
hth
Ludwig
Am 16.06.23 um 17:53 schrieb Simon via QGIS-User:
> Hi all,
> Excel spreadsheets can be imported into QGIS when they're formatted as
> Delimited text layers, but is it possible to import a spreadsheet with
> various cells containing different equations and then display them on
> a map?
> Thanks,
> Simon
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230616/68b3698b/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230616/68b3698b/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230616/68b3698b/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230616/68b3698b/attachment-0005.png>
More information about the QGIS-User mailing list
