[Qgis-user] (no subject)
Loke Jian Munn jm.loke at klk.com.my
Wed Jun 21 01:09:05 PDT 2023
As mention previously, I need NIR band to perform the NDVI, however my drone sensor does not record NIR band.
So, I trying another way which is crop counting from orthophoto with Python and Scikit Image. The whole process is geospatial as it works with raster and shapefiles and results are finally displayed on QGIS.
But the results I get are like below:
[cid:image004.png at 01D9A458.D04E73E0]
After Zoom in:
[cid:image005.png at 01D9A458.D04E73E0]
May I know what’s goes wrong ? I have attached the Python code above for references. For this project, I using an Orthomosaic layer with resolution of 5cm.
Appreciate if you can provide me some guidelines or insights in this as this is my first time touching python and scikit.
Thank you.
Regards,
Loke Jian Munn
Information Technology (IT) Department
[cid:image001.png at 01D9A41F.EC917F40]
KUALA LUMPUR KEPONG BERHAD
Wisma Taiko,
No. 1, Jalan S.P. Seenivasagam,
30000 Ipoh,Perak Darul Ridzuan,Malaysia
T    :  +605 240 8000 (ext. 2443)
[A close up of a sign    Description automatically generated]<https://clicktime.symantec.com/15tpDKjABDCCmu4drBEZD?h=4-LzQeEUOcKmp7sCwswGafke694l_dZCDQJ4Rb8N8bc=&u=http://www.klk.com.my/>[A close up of a sign    Description automatically generated]<https://clicktime.symantec.com/15tpJ9vSdpsoBqtZPjdhq?h=bX-LFOj0HrSJV_t-3L_WhMP3i5PRx5AtNBaHlI02C7k=&u=http://www.linkedin.com/company/klkberhad>
Sent: Tuesday, 6 June, 2023 6:09 PM
To: Loke Jian Munn <jm.loke at klk.com.my>; qgis-user at lists.osgeo.org
Subject:
Hi Loke
Richard suggested using a NDVI approach which would require data in the Near Infrared (NIR) band.  An orthomisaic would contain 3 colour bands, but not the NIR.  NDVI provides an understanding of plant greenness and health and may not be suitable for detecting oil palm's.
If you are getting 90 percent plus with your current approach , you may find that you will spend 4 times longer capturing the additional 10 percent.
NIR data,are available from various satellite sensors however, their resolution would not work at the individual plant level.
Some drone sensors record the NIR band.
Kirk Schmidt
Sent from my Galaxy
DISCLAIMER : This email and any attachments are confidential and intended solely for the addressee. If you are not the intended recipient, any disclosure, copying, distribution either whole or partial, is prohibited and may be unlawful. In such case, please delete this message and kindly notify the sender.
Kuala Lumpur Kepong Berhad
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230621/f97c1bd1/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230621/f97c1bd1/attachment-0005.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230621/f97c1bd1/attachment-0006.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230621/f97c1bd1/attachment-0007.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230621/f97c1bd1/attachment-0008.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230621/f97c1bd1/attachment-0009.png>
More information about the QGIS-User mailing list
