[Qgis-user] visibility when selecting one of several points in a location
Hugh Kelley hghklly at gmail.com
Thu Jun 29 11:04:44 PDT 2023
Hi all,
Sometimes when working with data, especially points, I'll have a stack of
several points in the same location, usually when the accuracy of the x/y
values is low.
In a lot of cases, if I'm selecting a point in a "stack" it will not appear
selected since it's covered by another point.
My understanding is that point drawing order is a function of the
datasource's row order.
I can solve my problem by using rule based symbology consistent with the
selection expression and turning off the "else" rule.
I'm wondering if there is any other shortcut I might use to avoid
rebuilding the symbology. Is there any way to set the drawing order so that
a selected feature is at the top? Or maybe to highlight a selected feature
so that it's slightly larger in addition to yellow.
thought I'd ask about existing solutions before considering putting
together a feature request/proposal/pr to expand the size of a selected
point/line/polygons.
Thanks!
Hugh
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230629/1cba8503/attachment.htm>
More information about the QGIS-User mailing list
