[Qgis-user] Fwd: Transformation of vertical datum for points
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Mar 16 06:53:06 PDT 2023
"The data is in EPSG:32825 (UTM32N/ETRS89)"..
This is of course : EPSG:25832 (UTM32N/ETRS89)" ...
-------- Videresendt meddelelse --------
Emne: 	Transformation of vertical datum for points
Dato: 	Thu, 16 Mar 2023 13:02:39 +0100
Fra: 	Bo Victor Thomsen <bo.victor.thomsen at gmail.com>
Til: 	qgis-user at lists.osgeo.org
Hi list -
I have a question regarding transformation of ellisoid heights to geoid
heights..
I have a dataset consisting of points, where the z coordinate is a
attribute column for the layer. (If necessary, this can be changed to a
3 dimensional layer type - or the x, y values can be placed i 2
attribute columns - whatever)
The data is in EPSG:32825 (UTM32N/ETRS89) and the present height values
are ellisoid height values for this CRS.
I would like to transform the height values the the corresponding DVR90
( EPSG:5799) geoid height values
Can this be done in QGIS using some kind of expression function. Or
using ogr2ogr ? or Postgis ??
Med venlig hilsen / Best regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230316/f9ed02ca/attachment.htm>
More information about the QGIS-User mailing list
