[Qgis-user] Qgis server : install on Linux Debian
celati Laurent laurent.celati at gmail.com
Fri Mar 17 05:08:56 PDT 2023
Good afternoon,
First, thank you so much for your replies.
I'm trying to give additional/updated inputs.
I confirm to you that i installed the server thanks to a `apt install
qgis-server` command.
Please read the results when i tape this command :
*root at xxxxxx:/etc/apache2/sites-available# dpkg -s qgis-serverPackage:
qgis-serverStatus: install ok installedPriority: optionalSection:
scienceInstalled-Size: 9019Maintainer: Debian GIS Project
<pkg-grass-devel at lists.alioth.debian.org
<pkg-grass-devel at lists.alioth.debian.org>>Architecture: amd64Source:
qgisVersion: 3.10.14+dfsg-1Replaces: qgis-mapserverProvides:
qgis-mapserverDepends: python3-qgis (= 3.10.14+dfsg-1), qgis-providers (=
3.10.14+dfsg-1), libc6 (>= 2.29), libexiv2-27 (>= 0.27.3), libfcgi0ldbl (>=
2.4.2), libgcc-s1 (>= 3.0), libqgis-core3.10.14 (>= 3.10.2),
libqgis-server3.10.14 (>= 3.10.2), libqt5core5a (>= 5.15.1), libqt5gui5 (>=
5.3.0) | libqt5gui5-gles (>= 5.3.0), libqt5webkit5 (>= 5.212.0~alpha3),
libqt5widgets5 (>= 5.0.2), libqt5xml5 (>= 5.0.2), libstdc++6 (>=
5.2)Conflicts: qgis-mapserverDescription: QGIS server providing various OGC
services QGIS is a Geographic Information System (GIS) which manages,
analyzes and display databases of geographic information. This package
contains the QGIS server.Homepage: https://qgis.org/ <https://qgis.org/>*
Regarding the debian version installed :
lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 11 (bullseye)
Release:        11
Codename:       bullseye
Within the qgis.demo.conf, i took the liberty to change the IP value of the
server by the name of the server.
Then :
root at XXXXXX:/etc/apache2/sites-available# a2ensite XXXXXXXX
ERROR: Site XXXXXX does not exist!
Then. After a restart of Apache. I get this error message :
root at XXXXX:/etc/apache2/sites-available# curl
XXXX.fr/cgi-bin/qgis_mapserv.fcgi
<ServerException>Project file error</ServerException>
Thanks a lot for your help.
Le mer. 15 mars 2023 à 20:28, Aguilar Bolivar, Rosa (UT-ITC) <
r.aguilar at utwente.nl> a écrit :
> Hi,
> There is a helpful material at:
> https://github.com/elpaso/qgis3-server-vagrant,
> Also a docker container image at:
> https://github.com/elpaso/qgis-server-docker.
> Perhaps you could use this material as a starting point.
> Hope this helps.
> Best,
> Rosa
> Dr. Rosa Aguilar
> University of Twente
> Faculty of Geoinformation Science and Earth Observation
> Connect with me on LinkedIn
> <https://www.linkedin.com/in/rosamaguilar/?locale=en_US>
> https://rosaguilar.github.io
> The essential is invisible to the eye. Saint-Exupéry
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *celati
> Laurent via QGIS-User
> *Sent:* Wednesday, March 15, 2023 4:23 PM
> *To:* qgis-user <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Qgis server : install on Linux Debian
> Good afternnon,
> I want to install Qgis server on my Linux Debian server virtual .For now,
> it's not working.
> FYI, I already have a working apache server and used for geoserver and
> geonetwork.
> I followed the Qgis server doc/tutorial:
> https://docs.qgis.org/3.22/en/docs/training_manual/qgis_server/install.html
> <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.22%2Fen%2Fdocs%2Ftraining_manual%2Fqgis_server%2Finstall.html&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298340593%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=rRTqcYX4IWpYNx2APq5UzngB5idQy5WccQsLsEzR8Ys%3D&reserved=0>
> https://docs.qgis.org/3.22/en/docs/server_manual/getting_started.html#installation-on-debian-based-systems
> <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.22%2Fen%2Fdocs%2Fserver_manual%2Fgetting_started.html%23installation-on-debian-based-systems&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298360503%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=jh35omGXX%2FoArpmE234Xr%2BxuHzVDflxKav8EVzWpHXA%3D&reserved=0>
> FYI, when I test the executable, here is the message.The version seems to
> be qgis 3.10 (and not 3.22). And the status message is 200 and not 400.
> *[code]root at XXXXXXXXXX:/usr/lib/cgi-bin#
> /usr/lib/cgi-bin/qgis_mapserv.fcgi --version Application path not
> initialized Application path not initialized Application path not
> initialized QStandardPaths: runtime directory '/run/user/1001' is not owned
> by UID 0, but a directory permissions 0700 owned by UID 1001 GID 1001
> Warning 1: Unable to find ECW driver to unload from GDAL_SKIP environment
> variable. Warning 1: Unable to find ECW driver to unload from GDAL_SKIP
> environment variable. Warning 1: Unable to find driver JP2ECW to unload
> from GDAL_SKIP environment variable. Initializing server modules from
> "/usr/lib/qgis/server" "Checking /usr/lib/qgis/server for native services
> modules" "Loading native module /usr/lib/qgis/server/libdummy.so" "Loading
> native module /usr/lib/qgis/server/libwcs.so" "Loading native module
> /usr/lib/qgis/server/libwfs.so" "Loading native module
> /usr/lib/qgis/server/libwfs3.so" "Loading native module
> /usr/lib/qgis/server/libwms.so" "Loading native module
> /usr/lib/qgis/server/libwmts.so" <string>:1: DeprecationWarning: setapi()
> is deprecated Logged warning: Loading a file that was saved with an older
> version of qgis (saved in 0.0.0, loaded in 3.10.14-A Coruña). Problems may
> occur. Content Length: 206 Content-Type: text/xml; charset=utf-8 [b]Server:
> Qgis FCGI server - QGis version 3.10.14-A Coruña Status: 200
> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc
> <https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.opengis.net%2Fogc&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298370457%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=quyHw82PqJGv79OxOfI2MD360x9T0B7%2FP%2Bn2teJ%2FNUk%3D&reserved=0>"
> version="1.3.0"> <ServiceException code="Service configuration
> error">Service unknown or unsupported</ServiceException>
> </ServiceExceptionReport>*
> I installed mod_fcgid successfully.
> As I already Apache installed. What should I do ? I would like to be able
> to coexist geoserver, geonetwork and qgis server. I would like to be able
> to add for qgis server a https://SERVEUR_NAME/qgis_server URL.
> I created a qgis.demo.conf file under etc/apache2/sites-available. I only
> replaced ServerName with my server's IP. I haven't changed anything else.
> Given my needs and working environment, should I modify the first line of
> the file? :
> <VirtualHost *:80>[
> *I created the directories that will store the QGIS server logs and the
> authentication database logs: [code]mkdir -p /var/log/qgis/ chown
> www-data:www-data /var/log/qgis mkdir -p /home/qgis/qgisserverdb chown
> www-data:www-data /home/qgis/qgisserverdb*
> I enabled fgcid mode and virtual host. But after restarting apache, I got
> nothing.
> * root at XXXXXXXXXXXXXXXX:/etc# curl
> http://XXXXXXX.fr/cgi-bin/qgis_mapserv.fcgi
> <https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fxxxxxxx.fr%2Fcgi-bin%2Fqgis_mapserv.fcgi&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298370457%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=LHyQONg9y4pr4%2F9qcdDO%2B%2FyvGrse7pstLR13cy%2F8EDc%3D&reserved=0>
> <!PUBLIC HTML DOCTYPE "-//IETF//HTML 2.0 DTD//EN"> <html><head> <title>301
> Moved Permanently</title> </head><body> <h1>Moved Permanently</h1> <p>The
> document has moved <a href="https://XXXXXXXXXXXcgi-bin/qgis_mapserv.fcgi
> <https://XXXXXXXXXXXcgi-bin/qgis_mapserv.fcgi>">here</a>.</p> <hr>
> <address>Apache/2.4.54 (Debian) Server at XXXXXXX.fr Port 80</address>
> </body></html>[/code]*
> Via the browser, when I try
> *XXXXX.fr/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities*
> It says Site Unreachable.
> If someone could help me? THANKS.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230317/2aa79411/attachment.htm>
More information about the QGIS-User mailing list
