[Qgis-user] Qgis server : install on Linux Debian
Jorge Gustavo Rocha jgr at geomaster.pt
Thu Mar 23 08:32:19 PDT 2023
You are using curl on the command line. You need to protect the url
between quotes.
Can you try again with quotes around the URL?
Regards,
Jorge
On 23/03/23 14:06, celati Laurent via QGIS-User wrote:
> Good morning,
> Thanks a lot for your message.
> I uninstalled everything I had installed up to now (from the Debian
> repository)  which only offered the qgis server 3.10 version.
> I added the official qgis repository which allowed to install the
> version of qgis server 3.30. For information,  the qgis project that I
> am trying to serve is version 3.28 and not 3.30.
> This is the current error message I am getting now:
> / curl
> http://SERVEUR_NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
> <http://SERVEUR_NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>
> [1] 395943
> [2] 395944
> root at SERVEUR_NAME:/home/qgis/projects# <?xml version="1.0"
> encoding="UTF-8"?>
> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc"
> version="1.3.0">
>   <ServiceException code="OperationNotSupported">Please add or check
> the value of the REQUEST parameter</ServiceException>
> </ServiceExceptionReport>
> ^C
> [1]- Done curl
> <http://SERVEUR_NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS>
> [2]+ Finished VERSION=1.3.0
> Do you know what is the request parameter within the URL ?
> Someone can help me? Thanks a lot.
> Le ven. 17 mars 2023 à 13:08, celati Laurent
> <laurent.celati at gmail.com> a écrit :
>     Good afternoon,
>     First, thank you so much for your replies.
>     I'm trying to give additional/updated inputs.
>     I confirm to you that i installed the server thanks to a `apt
>     install qgis-server` command.
>     Please read the results when i tape this command :
>     /root at xxxxxx:/etc/apache2/sites-available# dpkg -s qgis-server
>     Package: qgis-server
>     Status: install ok installed
>     Priority: optional
>     Section: science
>     Installed-Size: 9019
>     Maintainer: Debian GIS Project
>     <pkg-grass-devel at lists.alioth.debian.org>
>     Architecture: amd64
>     Source: qgis
>     Version: 3.10.14+dfsg-1
>     Replaces: qgis-mapserver
>     Provides: qgis-mapserver
>     Depends: python3-qgis (= 3.10.14+dfsg-1), qgis-providers (=
>     3.10.14+dfsg-1), libc6 (>= 2.29), libexiv2-27 (>= 0.27.3),
>     libfcgi0ldbl (>= 2.4.2), libgcc-s1 (>= 3.0), libqgis-core3.10.14
>     (>= 3.10.2), libqgis-server3.10.14 (>= 3.10.2), libqt5core5a (>=
>     5.15.1), libqt5gui5 (>= 5.3.0) | libqt5gui5-gles (>= 5.3.0),
>     libqt5webkit5 (>= 5.212.0~alpha3), libqt5widgets5 (>= 5.0.2),
>     libqt5xml5 (>= 5.0.2), libstdc++6 (>= 5.2)
>     Conflicts: qgis-mapserver
>     Description: QGIS server providing various OGC services
>      QGIS is a Geographic Information System (GIS) which manages,
>     analyzes and
>      display databases of geographic information.
>      This package contains the QGIS server.
>     Homepage: https://qgis.org//
>     Regarding the debian version installed :
>     lsb_release -a
>     No LSB modules are available.
>     Distributor ID: Debian
>     Description:    Debian GNU/Linux 11 (bullseye)
>     Release:        11
>     Codename:       bullseye
>     Within the qgis.demo.conf, i took the liberty to change the IP
>     value of the server by the name of the server.
>     Then :
>     root at XXXXXX:/etc/apache2/sites-available# a2ensite XXXXXXXX
>     ERROR: Site XXXXXX does not exist!
>     Then. After a restart of Apache. I get this error message :
>     root at XXXXX:/etc/apache2/sites-available# curl
>     XXXX.fr/cgi-bin/qgis_mapserv.fcgi
>     <ServerException>Project file error</ServerException>
>     Thanks a lot for your help.
>     Le mer. 15 mars 2023 à 20:28, Aguilar Bolivar, Rosa (UT-ITC)
>     <r.aguilar at utwente.nl> a écrit :
>         Hi,
>         There is a helpful material at:
>         https://github.com/elpaso/qgis3-server-vagrant,
>         Also a docker container image
>         at:https://github.com/elpaso/qgis-server-docker.
>         Perhaps you could use this material as a starting point.
>         Hope this helps.
>         Best,
>         Rosa
>         Dr. Rosa Aguilar
>         University of Twente
>         Faculty of Geoinformation Science and Earth Observation
>         Connect with me on LinkedIn
>         <https://www.linkedin.com/in/rosamaguilar/?locale=en_US>
>         https://rosaguilar.github.io <https://rosaguilar.github.io/>__
>         The essential is invisible to the eye. Saint-Exupéry
>         *From:*QGIS-User <qgis-user-bounces at lists.osgeo.org> *On
>         Behalf Of *celati Laurent via QGIS-User
>         *Sent:* Wednesday, March 15, 2023 4:23 PM
>         *To:* qgis-user <qgis-user at lists.osgeo.org>
>         *Subject:* [Qgis-user] Qgis server : install on Linux Debian
>         Good afternnon,
>         I want to install Qgis server on my Linux Debian server
>         virtual .For now, it's not working.
>         FYI, I already have a working apache server and used for
>         geoserver and geonetwork.
>         I followed the Qgis server doc/tutorial:
>         https://docs.qgis.org/3.22/en/docs/training_manual/qgis_server/install.html
>         <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.22%2Fen%2Fdocs%2Ftraining_manual%2Fqgis_server%2Finstall.html&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298340593%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=rRTqcYX4IWpYNx2APq5UzngB5idQy5WccQsLsEzR8Ys%3D&reserved=0>
>         https://docs.qgis.org/3.22/en/docs/server_manual/getting_started.html#installation-on-debian-based-systems
>         <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.22%2Fen%2Fdocs%2Fserver_manual%2Fgetting_started.html%23installation-on-debian-based-systems&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298360503%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=jh35omGXX%2FoArpmE234Xr%2BxuHzVDflxKav8EVzWpHXA%3D&reserved=0>
>         FYI, when I test the executable, here is the message.The
>         version seems to be qgis 3.10 (and not 3.22). And the status
>         message is 200 and not 400.
>         /[code]root at XXXXXXXXXX:/usr/lib/cgi-bin#
>         /usr/lib/cgi-bin/qgis_mapserv.fcgi --version
>         Application path not initialized
>         QStandardPaths: runtime directory '/run/user/1001' is not
>         owned by UID 0, but a directory permissions 0700 owned by UID
>         1001 GID 1001
>         Warning 1: Unable to find ECW driver to unload from GDAL_SKIP
>         environment variable.
>         Warning 1: Unable to find driver JP2ECW to unload from
>         GDAL_SKIP environment variable.
>         Initializing server modules from "/usr/lib/qgis/server"
>         "Checking /usr/lib/qgis/server for native services modules"
>         "Loading native module /usr/lib/qgis/server/libdummy.so"
>         "Loading native module /usr/lib/qgis/server/libwcs.so"
>         "Loading native module /usr/lib/qgis/server/libwfs.so"
>         "Loading native module /usr/lib/qgis/server/libwfs3.so"
>         "Loading native module /usr/lib/qgis/server/libwms.so"
>         "Loading native module /usr/lib/qgis/server/libwmts.so"
>         <string>:1: DeprecationWarning: setapi() is deprecated
>         Logged warning: Loading a file that was saved with an older
>         version of qgis (saved in 0.0.0, loaded in 3.10.14-A Coruña).
>         Problems may occur.
>         Content Length: 206
>         Content-Type: text/xml; charset=utf-8
>         [b]Server: Qgis FCGI server - QGis version 3.10.14-A Coruña
>         Status: 200
>         <https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.opengis.net%2Fogc&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298370457%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=quyHw82PqJGv79OxOfI2MD360x9T0B7%2FP%2Bn2teJ%2FNUk%3D&reserved=0>"
>         version="1.3.0">
>         <ServiceException code="Service configuration error">Service
>         unknown or unsupported</ServiceException>
>         </ServiceExceptionReport>/
>         I installed mod_fcgid successfully.
>         As I already Apache installed. What should I do ? I would like
>         to be able to coexist geoserver, geonetwork and qgis server. I
>         would like to be able to add for qgis server a
>         https://SERVEUR_NAME/qgis_server
>         <https://SERVEUR_NAME/qgis_server> URL.
>         I created a qgis.demo.conf file under
>         etc/apache2/sites-available. I only replaced ServerName with
>         my server's IP. I haven't changed anything else. Given my
>         needs and working environment, should I modify the first line
>         of the file? :
>         <VirtualHost *:80>[
>         /I created the directories that will store the QGIS server
>         logs and the authentication database logs:
>         [code]mkdir -p /var/log/qgis/
>         chown www-data:www-data /var/log/qgis
>         mkdir -p /home/qgis/qgisserverdb
>         chown www-data:www-data /home/qgis/qgisserverdb/
>         I enabled fgcid mode and virtual host. But after restarting
>         apache, I got nothing.
>         root at XXXXXXXXXXXXXXXX:/etc# curl
>         http://XXXXXXX.fr/cgi-bin/qgis_mapserv.fcgi
>         <https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fxxxxxxx.fr%2Fcgi-bin%2Fqgis_mapserv.fcgi&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298370457%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=LHyQONg9y4pr4%2F9qcdDO%2B%2FyvGrse7pstLR13cy%2F8EDc%3D&reserved=0>
>         <!PUBLIC HTML DOCTYPE "-//IETF//HTML 2.0 DTD//EN">
>         <html><head>
>         <title>301 Moved Permanently</title>
>         </head><body>
>         <h1>Moved Permanently</h1>
>         <p>The document has moved <a
>         href="https://XXXXXXXXXXXcgi-bin/qgis_mapserv.fcgi
>         <https://XXXXXXXXXXXcgi-bin/qgis_mapserv.fcgi>">here</a>.</p>
>         <hr>
>         <address>Apache/2.4.54 (Debian) Server at XXXXXXX.fr Port
>         80</address>
>         </body></html>[/code]/
>         Via the browser, when I try
>         /XXXXX.fr/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities/
>         It says Site Unreachable.
>         If someone could help me? THANKS.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Jorge Gustavo Rocha
Geomaster, LDA
"Take the open source journey with us"
VAT/NIF: PT 510 906 109
Phone: +351 253 257 173 (landline)
Mobile: +351 910 333 888 (cellular)
Rua Afonso Palmeira, 31, 7 D
4715-278 Braga
PORTUGAL
GPS 41.54627, -8.40432
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230323/7064d3cc/attachment-0001.htm>
More information about the QGIS-User mailing list
