[Qgis-user] Qgis server : install on Linux Debian
celati Laurent laurent.celati at gmail.com
Sun Mar 26 23:36:49 PDT 2023
Thanks a lot Andrea.
You right. How to point out this big error in the doc which personally hurt
me a lot? ;-)
Le dim. 26 mars 2023 à 23:47, celati Laurent <laurent.celati at gmail.com> a
écrit :
> Thanks for your help.
> For information, I have no log file generated in /var/log/qgis/ . I post
> below updates and more test results. I used the project and data provided
> with the documentation
> When i enter :
> *http://SERVER/qgisserver?MAP=/home/qgis/projects/world.qgs&LAYERS=continents&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180
> <http://SERVER/qgisserver?MAP=/home/qgis/projects/world.qgs&LAYERS=continents&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180>*
> I obtain :
> *Not Found The requested URL was not found on this server. Apache/2.4.54
> (Debian) Server SERVER Port 80*
> And when i enter :
> http://SERVER/cgi-bin/qgis_mapserv.fcgi
> SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
> I obtain :
>   This XML file does not appear to have any style information associated with it. The document tree is shown below.
>     <WMS_Capabilities xmlns:sld="http://www.opengis.net/sld" xmlns="http://www.opengis.net/wms" xmlns:qgs="http://www.qgis.org/wms" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0" xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd http://www.qgis.org/wms http://SERVER/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&REQUEST=GetSchemaExtension">
>     <Service>
>     <Name>WMS</Name>
>     <Title>QGIS Server Demo</Title>
>     <Abstract>
>     <![CDATA[ This is a simple World map that showcases QGIS Server capabilities. ]]>
>     </Abstract>
>     <KeywordList>
>     <Keyword vocabulary="ISO">infoMapAccessService</Keyword>
>     <Keyword>QGIS Server World</Keyword>
>     </KeywordList>
>     <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://SERVER/cgi-bin/qgis_mapserv.fcgi"/>
>     <ContactInformation>
>     <ContactPersonPrimary>
>     <ContactPerson>Tudor Bărăscu</ContactPerson>
>     <ContactOrganization>qgis.org</ContactOrganization>
>     </ContactPersonPrimary>
>     <ContactElectronicMailAddress>tudor.barascu at qtibia.ro</ContactElectronicMailAddress>
>     </ContactInformation>
>     <Fees>conditions unknown</Fees>
>     <AccessConstraints>None</AccessConstraints>
>     </Service>
>     <Capability>
>     <Request>
>     <GetCapabilities>
>     <Format>text/xml</Format>
>     <DCPType>
>     <HTTP>
>     <Get>
>     <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://SERVER/cgi-bin/qgis_mapserv.fcgi?"/>
>     </Get>
>     </HTTP>
>     </DCPType>
>     </GetCapabilities>
> Le jeu. 23 mars 2023 à 15:06, celati Laurent <laurent.celati at gmail.com> a
> écrit :
>> Good morning,
>> Thanks a lot for your message.
>> I uninstalled everything I had installed up to now (from the Debian
>> repository)  which only offered the qgis server 3.10 version.
>> I added the official qgis repository which allowed to install the version
>> of qgis server 3.30. For information,  the qgis project that I am trying to
>> serve is version 3.28 and not 3.30.
>> This is the current error message I am getting now:
>> * curl
>> http://SERVEUR_NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>> <http://SERVEUR_NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>[1]
>> 395943[2] 395944root at SERVEUR_NAME:/home/qgis/projects# <?xml version="1.0"
>> encoding="UTF-8"?><ServiceExceptionReport xmlns="http://www.opengis.net/ogc
>> <http://www.opengis.net/ogc>" version="1.3.0">  <ServiceException
>> code="OperationNotSupported">Please add or check the value of the REQUEST
>> parameter</ServiceException></ServiceExceptionReport>^C[1]- Done curl
>> <http://SERVEUR_NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS>[2]+ Finished
>> VERSION=1.3.0*
>> Do you know what is the request parameter within the URL ?
>> Someone can help me? Thanks a lot.
>> Le ven. 17 mars 2023 à 13:08, celati Laurent <laurent.celati at gmail.com>
>> a écrit :
>>> Good afternoon,
>>> First, thank you so much for your replies.
>>> I'm trying to give additional/updated inputs.
>>> I confirm to you that i installed the server thanks to a `apt install
>>> qgis-server` command.
>>> Please read the results when i tape this command :
>>> *root at xxxxxx:/etc/apache2/sites-available# dpkg -s qgis-serverPackage:
>>> qgis-serverStatus: install ok installedPriority: optionalSection:
>>> scienceInstalled-Size: 9019Maintainer: Debian GIS Project
>>> <pkg-grass-devel at lists.alioth.debian.org
>>> <pkg-grass-devel at lists.alioth.debian.org>>Architecture: amd64Source:
>>> qgisVersion: 3.10.14+dfsg-1Replaces: qgis-mapserverProvides:
>>> qgis-mapserverDepends: python3-qgis (= 3.10.14+dfsg-1), qgis-providers (=
>>> 3.10.14+dfsg-1), libc6 (>= 2.29), libexiv2-27 (>= 0.27.3), libfcgi0ldbl (>=
>>> 2.4.2), libgcc-s1 (>= 3.0), libqgis-core3.10.14 (>= 3.10.2),
>>> libqgis-server3.10.14 (>= 3.10.2), libqt5core5a (>= 5.15.1), libqt5gui5 (>=
>>> 5.3.0) | libqt5gui5-gles (>= 5.3.0), libqt5webkit5 (>= 5.212.0~alpha3),
>>> libqt5widgets5 (>= 5.0.2), libqt5xml5 (>= 5.0.2), libstdc++6 (>=
>>> 5.2)Conflicts: qgis-mapserverDescription: QGIS server providing various OGC
>>> services QGIS is a Geographic Information System (GIS) which manages,
>>> analyzes and display databases of geographic information. This package
>>> contains the QGIS server.Homepage: https://qgis.org/ <https://qgis.org/>*
>>> Regarding the debian version installed :
>>> lsb_release -a
>>> No LSB modules are available.
>>> Distributor ID: Debian
>>> Description:    Debian GNU/Linux 11 (bullseye)
>>> Release:        11
>>> Codename:       bullseye
>>> Within the qgis.demo.conf, i took the liberty to change the IP value of
>>> the server by the name of the server.
>>> Then :
>>> root at XXXXXX:/etc/apache2/sites-available# a2ensite XXXXXXXX
>>> ERROR: Site XXXXXX does not exist!
>>> Then. After a restart of Apache. I get this error message :
>>> root at XXXXX:/etc/apache2/sites-available# curl
>>> XXXX.fr/cgi-bin/qgis_mapserv.fcgi
>>> <ServerException>Project file error</ServerException>
>>> Thanks a lot for your help.
>>> Le mer. 15 mars 2023 à 20:28, Aguilar Bolivar, Rosa (UT-ITC) <
>>> r.aguilar at utwente.nl> a écrit :
>>>> Hi,
>>>> There is a helpful material at:
>>>> https://github.com/elpaso/qgis3-server-vagrant,
>>>> Also a docker container image at:
>>>> https://github.com/elpaso/qgis-server-docker.
>>>> Perhaps you could use this material as a starting point.
>>>> Hope this helps.
>>>> Best,
>>>> Rosa
>>>> Dr. Rosa Aguilar
>>>> University of Twente
>>>> Faculty of Geoinformation Science and Earth Observation
>>>> Connect with me on LinkedIn
>>>> <https://www.linkedin.com/in/rosamaguilar/?locale=en_US>
>>>> https://rosaguilar.github.io
>>>> The essential is invisible to the eye. Saint-Exupéry
>>>> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *celati
>>>> Laurent via QGIS-User
>>>> *Sent:* Wednesday, March 15, 2023 4:23 PM
>>>> *To:* qgis-user <qgis-user at lists.osgeo.org>
>>>> *Subject:* [Qgis-user] Qgis server : install on Linux Debian
>>>> Good afternnon,
>>>> I want to install Qgis server on my Linux Debian server virtual .For
>>>> now, it's not working.
>>>> FYI, I already have a working apache server and used for geoserver and
>>>> geonetwork.
>>>> I followed the Qgis server doc/tutorial:
>>>> https://docs.qgis.org/3.22/en/docs/training_manual/qgis_server/install.html
>>>> <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.22%2Fen%2Fdocs%2Ftraining_manual%2Fqgis_server%2Finstall.html&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298340593%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=rRTqcYX4IWpYNx2APq5UzngB5idQy5WccQsLsEzR8Ys%3D&reserved=0>
>>>> https://docs.qgis.org/3.22/en/docs/server_manual/getting_started.html#installation-on-debian-based-systems
>>>> <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.22%2Fen%2Fdocs%2Fserver_manual%2Fgetting_started.html%23installation-on-debian-based-systems&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298360503%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=jh35omGXX%2FoArpmE234Xr%2BxuHzVDflxKav8EVzWpHXA%3D&reserved=0>
>>>> FYI, when I test the executable, here is the message.The version seems
>>>> to be qgis 3.10 (and not 3.22). And the status message is 200 and not 400.
>>>> *[code]root at XXXXXXXXXX:/usr/lib/cgi-bin#
>>>> /usr/lib/cgi-bin/qgis_mapserv.fcgi --version Application path not
>>>> initialized Application path not initialized Application path not
>>>> initialized QStandardPaths: runtime directory '/run/user/1001' is not owned
>>>> by UID 0, but a directory permissions 0700 owned by UID 1001 GID 1001
>>>> Warning 1: Unable to find ECW driver to unload from GDAL_SKIP environment
>>>> variable. Warning 1: Unable to find ECW driver to unload from GDAL_SKIP
>>>> environment variable. Warning 1: Unable to find driver JP2ECW to unload
>>>> from GDAL_SKIP environment variable. Initializing server modules from
>>>> "/usr/lib/qgis/server" "Checking /usr/lib/qgis/server for native services
>>>> modules" "Loading native module /usr/lib/qgis/server/libdummy.so" "Loading
>>>> native module /usr/lib/qgis/server/libwcs.so" "Loading native module
>>>> /usr/lib/qgis/server/libwfs.so" "Loading native module
>>>> /usr/lib/qgis/server/libwfs3.so" "Loading native module
>>>> /usr/lib/qgis/server/libwms.so" "Loading native module
>>>> /usr/lib/qgis/server/libwmts.so" <string>:1: DeprecationWarning: setapi()
>>>> is deprecated Logged warning: Loading a file that was saved with an older
>>>> version of qgis (saved in 0.0.0, loaded in 3.10.14-A Coruña). Problems may
>>>> occur. Content Length: 206 Content-Type: text/xml; charset=utf-8 [b]Server:
>>>> Qgis FCGI server - QGis version 3.10.14-A Coruña Status: 200
>>>> <https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.opengis.net%2Fogc&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298370457%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=quyHw82PqJGv79OxOfI2MD360x9T0B7%2FP%2Bn2teJ%2FNUk%3D&reserved=0>"
>>>> version="1.3.0"> <ServiceException code="Service configuration
>>>> error">Service unknown or unsupported</ServiceException>
>>>> </ServiceExceptionReport>*
>>>> I installed mod_fcgid successfully.
>>>> As I already Apache installed. What should I do ? I would like to be
>>>> able to coexist geoserver, geonetwork and qgis server. I would like to be
>>>> able to add for qgis server a https://SERVEUR_NAME/qgis_server URL.
>>>> I created a qgis.demo.conf file under etc/apache2/sites-available. I
>>>> only replaced ServerName with my server's IP. I haven't changed anything
>>>> else. Given my needs and working environment, should I modify the first
>>>> line of the file? :
>>>> <VirtualHost *:80>[
>>>> *I created the directories that will store the QGIS server logs and the
>>>> authentication database logs: [code]mkdir -p /var/log/qgis/ chown
>>>> www-data:www-data /var/log/qgis mkdir -p /home/qgis/qgisserverdb chown
>>>> www-data:www-data /home/qgis/qgisserverdb*
>>>> I enabled fgcid mode and virtual host. But after restarting apache, I
>>>> got nothing.
>>>> * root at XXXXXXXXXXXXXXXX:/etc# curl
>>>> http://XXXXXXX.fr/cgi-bin/qgis_mapserv.fcgi
>>>> <https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fxxxxxxx.fr%2Fcgi-bin%2Fqgis_mapserv.fcgi&data=05%7C01%7Cr.aguilar%40utwente.nl%7C9d9e7a09e0af46dcb9e308db25694617%7C723246a1c3f543c5acdc43adb404ac4d%7C0%7C0%7C638144906298370457%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=LHyQONg9y4pr4%2F9qcdDO%2B%2FyvGrse7pstLR13cy%2F8EDc%3D&reserved=0>
>>>> <!PUBLIC HTML DOCTYPE "-//IETF//HTML 2.0 DTD//EN"> <html><head> <title>301
>>>> Moved Permanently</title> </head><body> <h1>Moved Permanently</h1> <p>The
>>>> document has moved <a href="https://XXXXXXXXXXXcgi-bin/qgis_mapserv.fcgi
>>>> <https://XXXXXXXXXXXcgi-bin/qgis_mapserv.fcgi>">here</a>.</p> <hr>
>>>> <address>Apache/2.4.54 (Debian) Server at XXXXXXX.fr Port 80</address>
>>>> </body></html>[/code]*
>>>> Via the browser, when I try
>>>> *XXXXX.fr/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities*
>>>> It says Site Unreachable.
>>>> If someone could help me? THANKS.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230327/99377980/attachment-0001.htm>
More information about the QGIS-User mailing list
