[Qgis-user] QGIS server : Serve Postgis data ?
chris hermansen clhermansen at gmail.com
Mon Mar 27 09:26:52 PDT 2023
Laurent and list,
On Mon, Mar 27, 2023, 09:09 celati Laurent via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Good afternoon,
> Following to my previous message, I'm sharing my error. I am unable to
> serve a project containing postgis tables. For a first test, I'm just
> trying to serve one of the tables contained in my project. Here is the URL
> that I defined and tested. I tried to define max and min coordinates (BBOX)
> in the spatial reference system in 2154 (Lambert 93).
> * http://SERVEUR/cgi-bin/qgis_mapserv.fcgi?MAP=/home/qgis/projects/cigeo_forages.qgs&LAYERS=Cigeo_Zios_Po&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:2154&WIDTH=400&HEIGHT=200&BBOX=865347.7454,6820554.3899,886533.8979,6833234.8104
> <http://SERVEUR/cgi-bin/qgis_mapserv.fcgi?MAP=/home/qgis/projects/cigeo_forages.qgs&LAYERS=Cigeo_Zios_Po&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:2154&WIDTH=400&HEIGHT=200&BBOX=865347.7454,6820554.3899,886533.8979,6833234.8104>*
> Please read below the error message : Internal Server Error
> *The server encountered an internal error or misconfiguration and was
> unable to complete your request.Please contact the server administrator at
> webmaster at localhost to inform them of the time this error occurred, and the
> actions you performed just before this error.More information about this
> error may be available in the server error log.*
> If someone has any idea? To be complete, since the beginning of my tests,
> I have never had a log file generated in /var/log/qgis...This folder has
> been always remained empty
> Thanks a lot.
Anything interesting in the PostgreSQL log file? Or syslog?
> Le lun. 27 mars 2023 à 11:48, celati Laurent <laurent.celati at gmail.com> a
> écrit :
>> Good morning,
>> I have just (finally) validated the installation of Qgis server on our
>> Debian server.
>> I manage to serve/broadcast the .qgs project and the data made available
>> by the community (world.qgs project). These are shp files.
>> In parallel with the installation of Lizmap or QWC2, I would like to test
>> this time the fact to serve of qgis projects containing postgis tables from
>> our database. How to do this ? Especially for the definition of the URL?
>> How to define in the URL the sources of the postgis tables? The URL notably
>> has a LAYERS&...
>> How for example to publish all the postgis tables contained in a project,
>> without having to specify each of them in the URL?
>> Thank you so much.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230327/85ba6608/attachment.htm>
More information about the QGIS-User mailing list
