[Qgis-user] qgis2threejs plugin problem
Karl Magnus Jönsson Karl-Magnus.Jonsson at kristianstad.se
Thu Mar 30 02:50:25 PDT 2023
Hi!
I’ve managed to export a page with pointcloud. I don’t remember exactly but I think Luigi is on the right track. You have to copy the point cloud to the web server manually. It won’t export. It’s a bit tricky since the preview won’t load from the web server and the export not a local file. So you have to add it twice (local to see it in preview and from web server for the export) The URL may be tweaked in the data/index/scene.json file.
Hope this works for you.
Here is my example: https://kartor.kristianstad.se/publicerat/externt/3d/BN19-2137/
If anyone knows how to change the standard classification colors it would be nice to know. It works but it could be nicer.
Karl-Magnus Jönsson
Från: QGIS-User <qgis-user-bounces at lists.osgeo.org> För Luigi Pirelli via QGIS-User
Skickat: den 30 mars 2023 11:11
Till: Krisztián Kovács <perjesikovacs at gmail.com>
Kopia: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] qgis2threejs plugin problem
not so much time to answer and dig into... point cloud server in streaming as EPT need a webservice to be served.
I suppose you are adding them in QGIS and are served from some place.
So your web page (that do not show points) would be able to access that server that is serving points pointed by EPT.
In any case check F12 browser debug page to see network errors. I suppose this could give you info where the problem is.
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
* Hire a team: http://www.qcooperative.net
On Thu, 30 Mar 2023 at 11:02, Krisztián Kovács via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
Dear All,
I have a problem with the Qgis2threejs plugin.
when I want to export my point cloud data I get the following message.
[cid:image001.png at 01D962FB.3BFE86B0]
Earlier I've tried to replace this file that the message told in the export folder( it didn't worked)but now in the 3.3sw version Unfortunately i still don't know what should i do to get the correct index.html file which could show us the point cloud in the web browser
[cid:image002.png at 01D962FB.3BFE86B0]
Now I have an empty page without the my pointcloud.
[cid:image003.png at 01D962FB.3BFE86B0]
Does anybody experience how to use this plugin correct?
Thanks  your advice.
Kovács Krisztián
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230330/c3209775/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230330/c3209775/attachment-0003.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230330/c3209775/attachment-0004.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230330/c3209775/attachment-0005.png>
More information about the QGIS-User mailing list
