[Qgis-user] Qgis server : problem with qgis server logs
Antonio Viscomi antoviscomi at gmail.com
Thu May 4 16:11:38 PDT 2023
Great!
Il gio 4 mag 2023, 14:33 celati Laurent <laurent.celati at gmail.com> ha
scritto:
> Thanks a lot. It 's works well now.
> Le jeu. 4 mai 2023 à 11:37, Etienne Trimaille <etrimaille at 3liz.com> a
> écrit :
>> According to the QGIS documentation :
>> https://docs.qgis.org/3.28/en/docs/server_manual/config.html#environment-variables
>> QGIS_SERVER_LOG_FILE is deprecated and will be removed, in favor of
>> QGIS_SERVER_LOG_STDERR.
>> You shouldn't use both variables, either one or the other. We recommend
>> using the non deprecated one, it's using the normal stderr, like a lot of
>> services on a server.
>> I'm just adding one more important information because it's about your
>> server security :
>> > If you go to
>> > http://YOURhost/cgi-bin/qgis_mapserv.fcgi
>> > It's qgis server active?
>> It's indeed needed to debug like this, in order to see HTTP requests. Use
>> curl/wget is needed.
>> But as an important security reminder, the QGIS server URL mustn't be
>> accessible from a public URL. Otherwise, it's possible to have sensitive
>> data about your server published. Moreover, if the URL of QGIS server is
>> published on the internet, then it's possible to totally bypass all user
>> permissions and ACL about projects, layers, features visibility which makes
>> Lizmap features about user, groups and rights useless.
>> https://docs.lizmap.com/current/en/install/pre_requirements.html#qgis-server-side
>> Just keep that in mind
>> Regards,
>> Le Jeudi, Mai 04, 2023 10:54 CEST, Antonio Viscomi <antoviscomi at gmail.com>
>> a écrit:
>> Hi Laurent,
>> If you go to
>> Il gio 4 mag 2023, 10:36 celati Laurent <laurent.celati at gmail.com> ha
>> scritto:
>>> Hi,
>>> Thanks and sorry to disturb you again. I tried to create manually the
>>> file qgislog.log in /var/log/qgis.
>>> Then i set chown www-data /var/log/qgis/qgislog.log
>>> and sudo chmod 775 /var/log/qgis/qgislog.log
>>> I reloaded and restarted apache. But the file qgislog.log is and remains
>>> empty.
>>> I don't know where the problem come from.
>>> Le jeu. 4 mai 2023 à 07:30, Etienne Trimaille <etrimaille at 3liz.com> a
>>> écrit :
>>>> Hi,
>>>> It's still possible to use QGIS_SERVER_LOG_FILE, but it's deprecated,
>>>> you can see it in the documentation
>>>> QGIS_SERVER_LOG_STDERR will send logs to stderr.
>>>> Le mer. 3 mai 2023 à 23:53, Antonio Viscomi via QGIS-User <
>>>> qgis-user at lists.osgeo.org> a écrit :
>>>>> Laurent,
>>>>> Please, try to create the file 'qgislog.log' manually first
>>>>> If doesn't works I don't know why
>>>>> Il mer 3 mag 2023, 18:18 celati Laurent <laurent.celati at gmail.com> ha
>>>>> scritto:
>>>>>> Hello,
>>>>>> Thanks. As you advice, i set FcgidInitialEnv QGIS_SERVER_LOG_FILE
>>>>>> Then a2ensite XXX.XXX.fr
>>>>>> Then i have reload apache systemctl reload apache2
>>>>>> But still no qgislog file has been created.
>>>>>> Le mer. 3 mai 2023 à 17:53, Antonio Viscomi <antoviscomi at gmail.com>
>>>>>> a écrit :
>>>>>>> in additions
>>>>>>> sudo chown myuser:wwwdata /var/log/qgis/qgislog.log
>>>>>>> Saluti
>>>>>>> Antonio
>>>>>>> Il giorno mer 3 mag 2023 alle ore 17:46 Antonio Viscomi <
>>>>>>> antoviscomi at gmail.com> ha scritto:
>>>>>>>> hi Laurent,
>>>>>>>> I set
>>>>>>>> FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/log/qgis/qgislog.log
>>>>>>>> also,
>>>>>>>> and works fine for me
>>>>>>>> Saluti
>>>>>>>> Antonio
>>>>>>>> Il giorno mer 3 mag 2023 alle ore 17:37 celati Laurent via
>>>>>>>> QGIS-User <qgis-user at lists.osgeo.org> ha scritto:
>>>>>>>>> Good afternoon,
>>>>>>>>> I work with Debian, Apache. Qgis server 3.30. And lizmap. The
>>>>>>>>> lizmap log deals with a problem regarding my qgis server logs.
>>>>>>>>> In the /etc/apache2/sites-available i have created a file
>>>>>>>>> XXX.XXX.conf with ths part of content  :
>>>>>>>>>   # QGIS log
>>>>>>>>>   FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1
>>>>>>>>>   FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
>>>>>>>>> And i have create the directories that will store the QGIS Server
>>>>>>>>> logs
>>>>>>>>> mkdir -p /var/log/qgis/
>>>>>>>>> chown www-data:www-data /var/log/qgis
>>>>>>>>> But, there are never no log file created within this folder. Do
>>>>>>>>> you know why ? Do i have to restart qgis server ?
>>>>>>>>> I know how to restart apache (systemctl restart apache2).
>>>>>>>>> But how to restart qgis server ?
>>>>>>>>> Thanks a lot for your guidances.
>>>>>>>>> _______________________________________________
>>>>>>>>> QGIS-User mailing list
>>>>>>>>> QGIS-User at lists.osgeo.org
>>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230505/2381ca05/attachment.htm>
More information about the QGIS-User mailing list
