[Qgis-user] 3D Moon models with QGIS
Megan Eskey
megan.eskey at reloquence.com
Sat May 6 05:29:35 PDT 2023
Thanks, Kirk,
I have written two position papers based on a planetary address framework,
and have named and defined the first 32 roads in space based on that
framework. The papers are as yet unpublished, but have been shared with
various space organizations and companies such as The Planetary Society in
Pasadena and the Space Tourism Society in LA. I am looking for mapping
partners who could help me to make the first lunar road map based on my
white paper and Executive Report.
If interested, please email me at Megan.Eskey at reloquence.com and I'd be
happy to share the documents. I am a retired NASA employee with a
background in AI and web management, and Reloquence is my own company.
Megan
ᐧ
On Sat, May 6, 2023 at 6:34 AM kirk <kirk at nortekresources.com> wrote:
> Hi Megan
> Thanks for the interesting question and link. Yes QGIS gas the tools to
> complete this analysis.
> First generate a slope raster from your dem. You can use the slope tool
> in the Processing Toolbox>raster terrain analysis folder.
> The result will be a raster with the slopes of your study area. You can
> then use the raster calculator to convert any pixels with a slope greater
> than your threshold value to either a large number or the raster null
> value. The remaining cells will allow you to visualize a route between 2
> points. See this post for more details.
> https://gis.stackexchange.com/questions/166104/using-dtm-slope-map-to-find-shortest-route-between-two-locations-using-qgis
> To actually generste a route between 2 points , use a least cost path.
> There is a least cost path plug-in which will generate a vector lines to
> connect 2 points once you have the slope raster generated.
> Kirk
> Sent from my Galaxy
> -------- Original message --------
> From: Megan Eskey via QGIS-User <qgis-user at lists.osgeo.org>
> Date: 2023-05-05 7:16 p.m. (GMT-04:00)
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] 3D Moon models with QGIS
> I am curious about the capabilities of QGIS. I came across this
> interesting project to make a 3D map of the Moon, but now I would like to
> generate routes (rover traverses) based on slope data, specifically the low
> slope route between two point locations.
> Is that possible? Any tips or tricks would be helpful.
> https://www.ursa.fi/fileadmin/ursa2010/Harrastus/Ryhmatapaamiset/aktapaaminen/2021/Kuukuvat_QGIS_ropponen.pdf
> Megan
> ᐧ
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230506/f9dba537/attachment.htm>
More information about the QGIS-User
