[Qgis-user] Creating presentation maps using grass maps
Rich Shepard
rshepard at appl-ecosys.com
Thu May 11 13:04:05 PDT 2023
On Thu, 11 May 2023, Micha Silver wrote:
> It's really simple. In the QGIS Browser tab, you'll find your GRASS
> GISDBASE directory, and inside there will be sub-directories of each
> Location and Mapset indicated by a special **GRASS icon**. Just drag those
> into the map canvas and you're good to go. Details here:
https://docs.qgis.org/3.28/en/docs/user_manual/grass_integration/grass_integration.html
Micha,
Thank you.
> Then follow the QGIS documentation on preparing map layouts:
> https://docs.qgis.org/3.28/en/docs/user_manual/print_composer/index.html
> When your map layout is ready, click the Save to PDF button.
That does look easy.
Best regards,
Rich
More information about the QGIS-User
