[Qgis-user] Click to open layer
Richard McDonnell richard.mcdonnell at opw.ie
Fri May 19 08:41:53 PDT 2023
Hi Grant,
Do you mean insert a GeoTIFF in?
If that's the case, then you want the following Action..
Type: Python
Description: Add Raster to Canvas or whatever you want
Action Text: qgis.utils.iface.addRasterLayer('[%filepath%][%filename%]','[%filename%]')
For the above to work, you will need two attributes in your Polygon, a "filepath" and a "filename" attribute. In the fileparh is the Path to the folder containing the GeoTiff and the filename is the name of the file you are looking to load... so something like this...
[cid:image001.png at 01D98A70.D05A4F50]
This should then load any GeoTIFF into your Canvas.
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poibl?
Office of Public Works
Sr?id Jonathan Swift, Baile ?tha Troim, Co na M?, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Grant Boxer via QGIS-User
Sent: 19 May 2023 09:47
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Click to open layer
I am sure there is a simple way to do this but I would like to click on a polygon and get it to open a tiff file into my map canvas. Do I use an Action and an "open" command?
Regards Grant Boxer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230519/d104ded3/attachment.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230519/d104ded3/attachment.png>
More information about the QGIS-User mailing list
