[Qgis-user] QGIS for safe organization use.
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri May 26 07:58:21 PDT 2023
Your data is your data! It will be safe if you keep it safe. If you have any concerns regarding the safety of QGIS, send a mail to the NRCAN Canadian mapping service in Sherbrooke Quebec. They use QGIS and other products. Between you and me, I would stick with QGIS as ArcGIS could lock you into proprietary file formats. I would say ArcGIS is the best alternative to QGIS!
Nicolas Cadieux
> Le 23 mai 2023 à 12:10, Simon via QGIS-User <qgis-user at lists.osgeo.org> a écrit :
> Hello,
> I work at the Department of National Defense for the Canadian government and had some questions regarding QGIS.
> Firstly, I'm working on a project to determine the seismic risk and vulnerability of all the department's buildings different Canadian Provinces. An important part of the project will be to create a geodatabase containing crucial information about each building. After, I plan to create a layer that will show the location of these buildings on a map.
> Now, a large portion of the information regarding the buildings and their locations is confidential, and so I'm wondering if the geodatabase and layer that I plan to create will be safe and protected, or if other users will have access to them since QGIS is free and open source?
> At first, I was planning to work with ArcGIS Pro but I'm currently waiting for a license. When or if it comes through, I'll stick with ArcGIS but for now QGIS seems to be the best alternative.
> If QGIS is not safe, are there other safe and similar softwares you can recommend?
> Thanks,
> Simon
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230526/f675ea97/attachment.htm>
More information about the QGIS-User
