[Qgis-user] Unable to find the write projection to make my map layers line up (Matthew Hartzell)
Darrell Carvalho darrellc1991 at gmail.com
Wed May 31 14:57:09 PDT 2023
> As far as I can tell, EPSG:6420 is likely the right projection for the
engineer imagery, given what your colleague reported.
If the engineering images are scanned in, did you georeference them to the
appropriate CRS, or did you Assign Projection?
Once you know that it lines up with the CRS you expect it to be in (in this
case, EPSG:6420)
The issue becomes whether to reproject the orthophoto and boundaries to
EPSG:6420, or the engineering lines to whatever shared projection is used
by the Ortho and parcels.
>> Message: 1
> Date: Tue, 30 May 2023 12:59:54 -0700
> From: Matthew Hartzell <matthew.hartzell at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Unable to find the write projection to make my
>         map layers line up
> Message-ID:
>         <CAFRa+T6gjzLzWvi0LEzW7regyNXG4x3RtOE=vg-sOV=
> QH9zxrA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hello everybody,
> This is my first time using this forum/mailing list. Please forgive me if
> I'm doing anything wrong...
> *QGIS version:* 3.12
> *OS: *Mac 12.1
> *Problem:*
> I am trying to project a map containing parcel boundaries (vector) and
> orthoimagery (raster) to match the projection used by a set of engineering
> drawings so that I can line my map layers up to match the engineering
> drawings.
> The engineer who made the engineering drawings told me that the projection
> she used was:
>    - *NAD83 (NSRS2011), CA State Plane Zone III, U.S. Survey Feet*
> I cannot find this precise projection in QGIS?s list of projections.
> However, I tried the following projections, and none of them worked (that
> is, none of them projected my map layers in a way that lines up with the
> engineering drawings as expected):
>    - *NAD83 / California zone 3 (EPSG: 26943)*
>    - *NAD83 / California zone 3 (ftUS) (EPSG: 2227)*
>    - *NAD83(2011) / California zone 3 (EPSG: 6419)*
>    - *NAD83(2011) / California zone 3 (ftUS) (EPSG: 6420)*
>    - *NAD83(HARN) / California zone 3 (EPSG: 2768)*
>    - *NAD83(HARN) / California zone 3 (ftUS) (EPSG: 2872)*
>    - *NAD83(NSRS2007) / California zone 3 (EPSG: 3493)*
>    - *NAD83(NSRS2007) / California zone 3 (ftUS) (EPSG: 3494)*
>    - *NAD_1983_HARN_StatePlane_California_III_FIPS_0403 (EPSG: 102243)*
>    - *NAD_1983_StatePlane_California_III_FIPS_0403_Feet (EPSG: 102643)*
> What am I doing wrong?
> Which projection should I be using in QGIS so that my map layers line up
> with the projection ?NAD83 (NSRS2011), CA State Plane Zone III, U.S. Survey
> Feet??
> Thank you
> Matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230531/dc025973/attachment.htm>
More information about the QGIS-User mailing list
