[Qgis-user] Opening the Data Source Manager crashes QGIS
Richard Duivenvoorde
rdmailings at duif.net
Thu Nov 9 03:00:20 PST 2023
Hi Rob,
IF it is indeed a google earth plugin, which is causing the crash, reinstalling will not help because plugins are installed in your (QGIS)-profile, not in your installation.
Is it constantly crashing?
So either remove the plugin (via the plugin manager), or go into your profile (Settings/User Profiles) and remove the plugin by hand.
A last option is to create a fresh profile, which will give you a profile without any plugin.
See https://docs.qgis.org/3.28/en/docs/user_manual/introduction/qgis_configuration.html#working-with-user-profiles
Hope This Helps :-)
On 11/9/23 11:47, Rob Dingen via QGIS-User wrote:
> Dear Forum,
> Forgive my ignorance and infancy level using QGIS
> Installed on IOS:
> QGIS version3.32.3-Lima
> Qt version5.15.2
> Python version3.9.5
> When I try to open the Data Source Manager the application crashes. I probably did something wrong with a google earth plugin.
> Removing and installing a new copy does not help
> Could anyone advise how to install a clean version without importing the files which cause the crash?
> Please keep in mind I am a novel user .. not a developer
> Grateful!
> Best
> Rob
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
