[Qgis-user] DataPlotly plugin (ubuntu) : ModuleNotFoundError: No module named 'pandas
Matteo Ghetta matteo.ghetta at gmail.com
Wed Nov 15 06:43:59 PST 2023
release 4.1.0 fixes this problem
Cheers
Matteo
On 11/3/23 14:55, celati Laurent via QGIS-User wrote:
> Good afternoon,
> I work with Qgis 3.34.0-Prizren on Ubuntu.
> I would like test and use the DataPlotly plugin.
> I succeed in installing this plugin via the qgis plugin manager. But
> when i try to enable it still into the plugin manager, i have an error
> message saying :
> In advance, thanks so much for your help.
> Below i paste the whole message
> Impossible de charger l'extension 'DataPlotly' provoque une erreur lors
> de l'appel à sa méthode classFactory()
> **ModuleNotFoundError: No module named 'pandas'**
> Traceback (most recent call last):
>    File "/usr/lib/python3/dist-packages/qgis/utils.py", line 423, in
> _startPlugin
>      plugins[packageName] = package.classFactory(iface)
>    File
> "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/__init__.py", line 33, in classFactory
>      from .data_plotly import DataPlotly
>    File "/usr/lib/python3/dist-packages/qgis/utils.py", line 888, in _import
>      mod = _builtin_import(name, globals, locals, fromlist, level)
>    File
> "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/data_plotly.py", line 36, in
>      from DataPlotly.processing.dataplotly_provider import
> DataPlotlyProvider
>    File
> "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/processing/dataplotly_provider.py", line 24, in
>      from DataPlotly.processing.dataplotly_scatterplot import
> DataPlotlyProcessingScatterPlot
>    File
> "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/processing/dataplotly_scatterplot.py", line 43, in
>      import pandas as pd
> Version de Python : 3.10.12 (main, Jun 11 2023, 05:26:28) [GCC 11.4.0]
> Version de QGIS : 3.34.0-Prizren Prizren, ffbdd678812
> Chemin Python :
> /usr/share/qgis/python
> /usr/share/qgis/python/plugins
> /usr/lib/python310.zip
> /usr/lib/python3.10
> /usr/lib/python3.10/lib-dynload
> /usr/local/lib/python3.10/dist-packages
> /home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/HCMGIS/forms
> /home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/SentinelHub/external/requests_oauthlib-1.3.1-py2.py3-none-any.whl
> /home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview
> /home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/res
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
