[Qgis-user] zoomToLayers pyqgis
Ludwig Kniprath ludwig at kni-online.de
Sat Nov 18 02:20:17 PST 2023
Hi Patrick,
what about
iface.mapCanvas().setExtent(layer.extent())
iface.mapCanvas().refresh()
or
iface.setActiveLayer(layer)
iface.zoomToActiveLayer()
hth
Ludwig
Am 18.11.23 um 09:32 schrieb Patrick Dunford via QGIS-User:
> Good day to all
> I want to call zoomToLayers in a pyqgis script to zoom the map canvas
> to a layer which I have just applied a filter to. I am not sure how to
> do it as all the documented uses of this method seem to apply to
> different things than to a layer.
> If the layer is not the currently active layer is there a method of
> this that can be called on a particular layer or selecting a
> particular layer as active then using the call that uses the active
> layer.
> e.g.
> project =QgsProject.instance()
> layer = project.mapLayersByName("Live Aerial Footprints")[0]
> layer.setSubsetString(aerialFilter)
> # insert code here to zoom to this layer
> Thanks
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
