[Qgis-user] Oriented Points
Huesmann, Michaela
michaela.huesmann at Stadt-Steinfurt.de
Mon Nov 27 04:34:15 PST 2023
Hello,
Thanks for pointing out that I can capture an attribute using rotation. I already know that I can use the angle attribute to rotate the symbol. But it is very difficult to determine the respective angle. If I type in the value manually, I have to correct it 5 times until it is exactly as it should. This is extremely unproductive. Rotating doesn't work with the "Rotate Object" tool.
From Geomedia, I'm used to the fact that when recording, you first click on the position point and then record the direction using the mouse position. That's what I was looking for in QGIS.
Best regards,
Michaela
Von: Ujaval Gandhi <ujaval at spatialthoughts.com>
Gesendet: Montag, 27. November 2023 12:32
An: Huesmann, Michaela <michaela.huesmann at Stadt-Steinfurt.de>
Cc: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Oriented Points
Just add an attribute for the rotation/orientation. You can visualize them using the technique shown here https://www.communityhealthmaps.org/blog/2019/02/21/mapping-field-photos-in-qgis<https://mailtrack.io/link/24fbc2e171ace0e065dca7ad8a988e33440db9bf?w=bWljaGFlbGEuaHVlc21hbm5Ac3RhZHQtc3RlaW5mdXJ0LmRl&url=https%3A%2F%2Fwww.communityhealthmaps.org%2Fblog%2F2019%2F02%2F21%2Fmapping-field-photos-in-qgis&userId=8747767&signature=218b5ea232016f3e>
Ujaval Gandhi
Spatial Thoughts
www.spatialthoughts.com<https://mailtrack.io/link/40f7fc9598c4280f3ffd3d282723fc66c1f08f7e?w=bWljaGFlbGEuaHVlc21hbm5Ac3RhZHQtc3RlaW5mdXJ0LmRl&url=http%3A%2F%2Fwww.spatialthoughts.com&userId=8747767&signature=2980740ac02388fd>
[Das Bild wurde vom Absender entfernt.]
On Mon, Nov 27, 2023 at 4:18 PM Huesmann, Michaela via QGIS-User <qgis-user at lists.osgeo.org> wrote:
Hello QGIS group,
how can I digitize oriented points in QGIS? I probably have to provide information when creating the geometry type fort he object class so that the rotation can be recorded.
Must be easy I guess but didn’t found out yet.
Best regards,
Michaela
[Kreisstadt Steinfurt]<http://www.steinfurt.de>
- 48565 Steinfurt
www.steinfurt.de<http://www.steinfurt.de>
Mit freundlichen Grüßen
im Auftrag
Michaela Huesmann
IT
Fachdienst Tiefbau
Tel.: +49 2552 925 219
Fax:
E-Mail: michaela.huesmann at Stadt-Steinfurt.de<mailto:michaela.huesmann at Stadt-Steinfurt.de>
Bitte denken Sie an die Umwelt, bevor Sie diese E-Mail ausdrucken.
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231127/cb586ba7/attachment.htm>
Type: image/jpeg
Desc: ~WRD000.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231127/cb586ba7/attachment.jpg>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231127/cb586ba7/attachment-0001.jpg>
More information about the QGIS-User
