[Qgis-user] Cannot save
Werner Macho
werner.macho at gmail.com
Thu Nov 30 05:57:26 PST 2023
Hi!
Good point Raymond, but I'd rather prefer to have a detailed description of
what has happened.
A simple sentence of:
"What is the problem as I cannot save."
is just not enough to provide a proper solution.
What are you trying to save? Where does the data come from?
Which operating system are you using? In which directory are you trying to
save to?
(local? network?).
without having detailed information all you will get is a rough guess out
of the "crystal ball".
regards
Werner
On Thu, Nov 30, 2023 at 2:52 PM Raymond Nijssen via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Just guessing.. You're trying to export your layer and when you chose a
> file name you just typed it into the edit widget and did not choose the
> [...] button next to it to open file browser. Now QGIS will attempt to
> save your gpkg file in the installation folder or some other directory
> where you don't have write access.
> Could that be?
> On 30-11-2023 08:00, Pekka Sarkola via QGIS-User wrote:
> > Hi!
> > It seems that you are trying to convert vector data to geopackage. What
> > tool are you using?
> > Rgs,
> > Pekka
> > Pekka Sarkola
> > Gispo Oy
> > pekka.sarkola at gispo.fi <mailto:pekka.sarkola at gispo.fi> - GSM +358
> > 40 725 2042
> > www.gispo.fi <http://www.gispo.fi/>– www.paikkatieto.com
> > <http://www.paikkatieto.com/>
> > ke 29. marrask. 2023 klo 12.22 Ilkka Haapalinna via QGIS-User
> > (qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>)
> kirjoitti:
> > Hi
> > I have version 3.28.13 Firenze.
> > When trying to save this is what I get in the attachment.
> > Please advice
> > Ilkka
> > QGIS-User mailing list
> > QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231130/39df8aed/attachment.htm>
More information about the QGIS-User
